1. stryKer BR's Avatar
    Hi guys, I do not know if it is normal but my S6 is getting heat, It is not heating to the point that I can not hold my device, but somehow it's bothering me.
    Sometimes it heats up a little even using light applications like facebook or whatsapp, It is more common to get hot when im using the camera, playing games or checking some photos at the gallery. when I do this kind of use it gets warm.
    When i charge my S6 it also gets hot.
    Please can someone help me ? How can i solve it ?
    Have you ever have warming problems with your s6 ?
    Thank u
    11-04-2015 07:29 PM
  2. stryKer BR's Avatar
    Hi, can someone help me ?
    11-12-2015 07:38 PM
  3. sLithery's Avatar
    If it is just warm then there is no problem with it and Samsung said that your phone gets warm while fast charging (from 0 - 60%).
    11-13-2015 02:22 AM
  4. vizionlife's Avatar
    its a mobile computer, batteries and processors get warm under use
    11-13-2015 08:32 AM
  5. Javier P's Avatar
    You could check in your battery stats if any app is taking an unusual high percentage. Another cause for heating up is a poor cell signal, specially when using mobile data.
    11-13-2015 09:11 AM
  1. Help! My pin is broken on my sony xpeira z3
    Last Post: 11-05-2015, 04:05 AM
  2. Problems with SD cards Galaxy s4 mini
    Last Post: 11-04-2015, 04:52 PM
  3. Replies: 2
    Last Post: 11-04-2015, 04:15 PM
  4. Having Major Problems with LGL15G
    By Emeraldv22 in forum Ask a Question
    Last Post: 11-04-2015, 04:05 PM
  5. Replies: 0
    Last Post: 11-04-2015, 03:15 PM
