1. godefroy28's Avatar
    i have galaxy s6 tmobile variant (sm-g925t). i tripped knox trying to root my phone. then i flashed a rom then another one not doing any backup. after that i flashed another one (just bored), everything was fine until when i was calling someone there was no voice heard or received from the other line. so a flashed a kernel not knowing if it will fix it or not. afterwards my phone is now on bootloop. we tried odin flashing DOI1 firmware, it says it was successfull but on the phone it rebooted then with android logo showed up saying "installing system firmware" with 1/3 loading bar then interrupted by "erasing" and then back on bootloop. smart switch did the same thing. is there any other way to enable usb debugging if theres not os installed? and how do i fix this phone
    11-13-2015 05:14 PM
  2. neebi007's Avatar
    Download latest stock rom from sam mobile for your variant and model. And flash via odin.
    This issue happened in xtrostelite rom if you do not have latest baseband.
    Your phone is in bootloop after kernel flash because you flashed wrong kernel.
    11-14-2015 05:11 AM
  3. godefroy28's Avatar
    the same thing happened. i am about to give up. what are my options for having someone fix it for me??
    btw on download mode it says
    current binary: custom
    system status: custom
    frp lock: off
    secure download: enabled
    knox warranty void: 1 (0x0304)
    ap swrev: b:3 k:2 s:2
    can these info help me to fix my phone?
    11-18-2015 05:16 PM
  1. No screen mirroring?
    By radiohawk in forum Samsung Galaxy Note 5
    Last Post: 07-07-2016, 09:10 PM
  2. Will T-Mobile note 5 work on Att and get LTE and vice versa?
    By cnotes2019 in forum Samsung Galaxy Note 5
    Last Post: 11-16-2015, 04:38 PM
  3. Replies: 1
    Last Post: 11-13-2015, 10:12 PM
  4. Replies: 1
    Last Post: 11-13-2015, 10:11 PM
  5. taking panorama selfies is almost impossible with front camera
    By mania626 in forum BlackBerry Android Phones
    Last Post: 11-13-2015, 07:13 PM
