1. xdollface8's Avatar
    Hi All,
    I just switched to the S6 edge from a turbo.
    Is there anyway to set the S6 to record my calls? This feature seems to be missing. I do not want to root the phone.
    I will take any other good tips/tricks as well.
    Thanks,
    L
    12-05-2015 07:51 PM
  2. neebi007's Avatar
    Hi All,
    Thanks,
    L
    call recording depends on csc (country sale code). if your country has prohibited call recording and other features it will automatically be switched off. so either root ur phone or download some call recording app from play store.
    12-06-2015 04:42 AM
  3. xdollface8's Avatar
    I live in New York. I am on Verizon.
    Any good suggestions on call Recording apps?
    12-06-2015 10:49 AM
  4. bullittmustang's Avatar
    ACR works great for me.
    xdollface8 likes this.
    12-06-2015 05:51 PM
  5. xdollface8's Avatar
    Got it. Thanks!
    12-08-2015 08:06 PM
  6. bullittmustang's Avatar
    Got it. Thanks!
    Sure, you can also go to your phones settings/applications/application manager, find ACR and unchecked show notifications and it will run in a stealth mode, undetectable.
    12-09-2015 08:09 PM
  1. tmo just canceld my simple choice plan how long be4 ?
    By Goosinurwife in forum T-Mobile
    Last Post: 12-12-2015, 06:29 AM
  2. can a unlocked att phone work on verizon ?
    By Goosinurwife in forum Verizon
    Last Post: 12-07-2015, 07:02 PM
  3. How to uninstall Microsoft OneDrive, Excel, Word?
    By awilliamsny in forum Samsung Galaxy Note 5
    Last Post: 12-07-2015, 01:15 PM
  4. We are 4 adults wanting to use a tmobile family plan.
    Last Post: 12-05-2015, 09:10 PM
  5. Replies: 2
    Last Post: 12-05-2015, 09:06 PM
