1. AntonioStoychev's Avatar
    Hey guys, recently I bought Galaxy S6 Edge and after a few days of usage I noticed something strange and I am wondering if its a hardware or software bug...
    So, when I put on a black wallpaper like the flower wallpaper on iPhone 6 and then appears some strange horizontal grayish line from the top of the display but that's only on the home screen and app drawer, the lockscreen looks good (deep blacks).When I open the picture in the gallery its good and sometimes turns out gray. I re-installed my stock ROM and the problem presist.When I open the picture on the computer it seems normal when I screen shot the phone it appears again and sometimes disappears?! I think there's some interference happening with the shadow and the blacks on the wallpaper and its bothering me because I didn't had those problems with my older galaxies.
    Any clues ? Already asked on the sammy's forums, but no attention has been given. S6 Edge: status bar shadow glitch?-20151213_130706.jpgS6 Edge: status bar shadow glitch?-20151213_130751.jpg
    12-13-2015 05:01 AM
  2. dpham48's Avatar
    Any clues ? Already asked on the sammy's forums, but no attention has been given. Click image for larger version.
ID:	209554Click image for larger version.
    I had the same issue, hopefully someone will notice.
    04-19-2016 02:59 AM
  3. anon(9408097)'s Avatar
    Factory reset. Seems like a software issue.
    04-20-2016 02:27 PM
  4. xaml's Avatar
    That is not an acceptable solution. I have this issue as well, on a Galaxy S6 running the most recent version of everything.
    03-03-2017 04:18 AM
  1. Samsung Galaxy s6 wont boot properly
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-04-2016, 07:39 AM
  2. S6 Drop Distance
    By mjthebeast in forum Samsung Galaxy S6 active
    Last Post: 12-16-2015, 07:46 PM
  3. Anyone else wish they had bought the s6 edge plus instead?
    By deadp1xel in forum Samsung Galaxy Note 5
    Last Post: 12-14-2015, 07:29 PM
  4. Samsung Galaxy s6 wont boot properly
    Last Post: 12-12-2015, 08:52 PM
  5. Play store crashes with search bar
    Last Post: 12-12-2015, 08:34 PM
