1. Cheburashkaa's Avatar
    Hi. I put a new screen protector on my phone, and I guess some water got into my home button. It isn't working to wake up the screen or exit apps. The finger print scanner is still working. Is there anything I can do? I am really freaking out.
    01-01-2016 02:31 AM
  2. Almeuit's Avatar
    Water damage could cause it. Is it still clicking when pressed?
    01-01-2016 03:09 AM
  3. Cheburashkaa's Avatar
    Yes, still clicking.
    01-01-2016 03:39 AM
  4. Cheburashkaa's Avatar
    I contacted AT&T. They said it was a hardware issue - checked for water damage and found none so they are sending me a replacement because of the hardware issue. So this is solved!
    01-01-2016 09:02 PM
  5. Noemis Smith's Avatar
    Follow the instructions in this video.
    If your phone is water resistant you may also try rinsing both buttons with water for about 30 seconds.
    Goodluck!
    11-24-2017 06:59 PM
  1. Does the Gear S smartwatch work with LG v10 smartphone?
    By william63 in forum Samsung Gear S
    Last Post: 01-03-2016, 11:01 AM
  2. Samsung Galaxy Note 5 not recognized by computer
    By Centuries Incorporated in forum Samsung Galaxy Note 5
    Last Post: 01-02-2016, 09:47 AM
  3. Do Not Disturb Until Next Alarm is back!
    By Carraser23 in forum Nexus 6P
    Last Post: 01-01-2016, 11:01 AM
  4. Wi-Fi connected but internet not working?
    Last Post: 01-01-2016, 04:16 AM
  5. Replies: 1
    Last Post: 01-01-2016, 04:02 AM
