1. David Ciszewski's Avatar
    the phone will only turn on if plugged in to thharger. I tired clear portion casha, factory reset and rebooting through the booter. what can I do. I got the latest Verizon wireless update when its on when plugged in and I unplug it it turns off and wont turn on. I do not istall apps unles its from Samsung or the play store
    01-30-2016 07:36 PM
  2. Tech-Newb's Avatar
    Your battery is bad. Try to replace your battery. Use your warranty if you still have it.
    Posted with ❤Love❤
    01-30-2016 10:00 PM
  3. David Ciszewski's Avatar
    how I just got it in October and never let it died out. also my friend s6 from Verizon did it too at the same time as mine next to each other. we were wondering if the person next to us with an rooted s6 with custom roms screwed with our phones even though ours are not rooted. is hacking a phone from another phone possible. do you think flashing the Samsung firmware might help. also I can get in to the maintence boot without the phone plugged in. just the screen wont boot on after restarting
    01-30-2016 10:56 PM
  4. Tech-Newb's Avatar
    Its worth trying to reflash the firmware. I dont think the rooted phone can hack yours. I suggest contacting an expert or samsung for help.
    Maybe, the motherboard is damaged and cant pull enough power from the battery to normally boot.
    Posted with ❤Love❤
    01-30-2016 11:14 PM
  5. David Ciszewski's Avatar
    how do you reflash a phone
    01-31-2016 06:40 AM
  6. Tech-Newb's Avatar
    You can follow this guide:
    http://www.w0lfdroid.com/2015/04/How...-Edge.html?m=1
    Be sure to download the right version for your model number.
    Flash at your own risk.
    Posted with ❤Love❤
    01-31-2016 07:14 AM
  1. Galaxy Tab A keyboard stuck on floating keyboard please help!!! How can I fix this?
    By AC Question in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 07-06-2016, 05:13 PM
  2. Replies: 3
    Last Post: 02-05-2016, 04:37 PM
  3. Replies: 1
    Last Post: 02-01-2016, 02:05 AM
  4. Wifi signal weak on Samsung S3
    Last Post: 01-31-2016, 06:13 PM
  5. Replies: 1
    Last Post: 01-31-2016, 03:02 AM
