My experience with Edge is not good... I frequently suffered hanging issues along with battery. I spent lot of money but its not worth buying. Now I have one Gionee S7 and its quite decent in its price and feature also. Pls samsung nid to work on their hanging issues.
I'd add the issue of the home button here.
The quality of home buttons on the 2015 galaxy phones have been horrible. The amount of money you pay for this phone and then the quality of materials you get is really unacceptable.
After a few weeks of usage the home button got scratched up SO BAD. Starts to look even worse after some months of usage. The chrome finished plastic as well as the weak plastic or glass used in the middle are just horrible!
I've noticed that they changed materials in the note 5 and edge plus, but I've seen them after a months use showing the same amount of damage as the S6 and the Edge variants. I just hope they fix this issue in this year's line up.
Otherwise I love the edge. I think it is the best compact phone out there.
You don't see billions of microscratches all over your home button?
