A AC Question Feb 4, 2016 #1 How do i remove the battery from the s6 edge How do i remove the battery from the s6 edge
A anon(632115) Well-known member Jan 5, 2012 4,315 0 0 Visit site Feb 4, 2016 #2 Re: How do i remove the battery from the s6 edge How to change your S6 and S6 Edge battery in 5 Steps
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Feb 5, 2016 #3 Or you don't risk breaking something, send it to Samsung and let them replace it. I believe it's $40 including the battery. (But if you killed the battery this quickly, you're doing something wrong.)
