1. gsal9296's Avatar
    Since yesterday my Samsung Galaxy s6 edge won't vibrate when I receive a text message, I always have it on vibrate because I'm always either at work or class, I checked all the settings for sound and notifications and vibration its at its max, also checked the settings in messaging app notifications and vibration is on, other than that vibration works when I receive other notifications, phone calls, and when I touch the screen, just won't vibrate when I receive a text please help, I already checked all settings.
    02-13-2016 08:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does that persist after a reboot?
    02-14-2016 12:20 AM
  3. gsal9296's Avatar
    Tried that and still doesn't work
    02-14-2016 11:11 PM
  4. B. Diddy's Avatar
    See if it still happens in Safe Mode: https://support.t-mobile.com/docs/DOC-21007
    02-16-2016 01:58 AM
  5. gsal9296's Avatar
    Still nothing, anything else I can try?
    02-17-2016 09:10 PM
  6. B. Diddy's Avatar
    Is this happening when the Messaging app is already open to the conversation thread, or does it also happen when the Messaging app is closed?
    02-18-2016 01:40 AM
  7. gsal9296's Avatar
    Yup still doesn't work, I really don't know the problem, I really appreciate your help tho
    B. Diddy likes this.
    02-18-2016 05:43 PM
  8. B. Diddy's Avatar
    Can you try a 3rd party SMS app, like Google Messenger, Textra or Chomp SMS? Or even Hangouts (setting Hangouts to be the default SMS app)?
    02-19-2016 10:14 PM
  9. gsal9296's Avatar
    Actually I wanted to solve the problem, not find a way around it, is there something wrong with the phone, because it vibrates with everything else,
    02-22-2016 09:17 PM
  10. B. Diddy's Avatar
    I'm suggesting other texting apps as a troubleshooting step. If the other texting apps give you vibration, then we can narrow the problem down to the stock Messaging app.
    02-23-2016 11:17 AM
  11. gsal9296's Avatar
    Oh alright, so which one should I download?
    02-23-2016 06:17 PM
  12. B. Diddy's Avatar
    Try Google Messenger.
    02-23-2016 06:27 PM
  1. Just ordered one for Verizon
    By BigCTM in forum Nexus 5X
    Last Post: 03-17-2016, 04:35 PM
  2. Replies: 4
    Last Post: 02-14-2016, 02:11 PM
  3. System Update Won't Install?
    By JustaUsernameLel in forum Ask a Question
    Last Post: 02-14-2016, 09:30 AM
  4. Replies: 1
    Last Post: 02-14-2016, 12:27 AM
  5. How to recieve and send pic by text
    Last Post: 02-13-2016, 08:55 PM
