1. Rumblee1's Avatar
    I like this phone very much. However, im on my 4th different screen protector. They just don't last very long along the edges. Can anyone recommend one that has a DRY application that will last. I want full screen coverage. Not just the middle. Thanks
    02-20-2016 02:36 PM
  2. jaltman's Avatar
    I like my Zagg Invisible Shield HD, easy to apply and long lasting....
    Its a kinda dry application. Wipe the sticky side with an 'activator', not exactly wet, not exactly dry.
    02-21-2016 07:36 AM
  3. Lodingi's Avatar
    Can you move it around while applying to line it up properly? I've tried 5 different screen protectors on my Edge+. They ranged in price from $7.99-$39.99. I returned 2, and tossed 3 in the garbage. It's been very frustrating to say the least.
    02-21-2016 07:52 AM
  4. jaltman's Avatar
    Yes, you can pick it back up and start over to get a perfect alignment. I would suggest your time is limited to get it done, but long enough that I was easily able to get it right. Also, while there is a squeegee to rub the bubbles out, lil bubbles miraculously leech out on their own over a couple days. I cleaned the glass with the microfiber cloth, used some canned air to blow off any remaining dust and got a perfect placement without any trouble.
    NFI YMMV
    02-21-2016 11:18 AM
  1. Home screen icons shifted left 1 cm
    By AC Question in forum Moto E
    Last Post: 09-05-2016, 04:29 AM
  2. How will the S7 be when applying screen protectors?
    By badkitties in forum Samsung Galaxy S7
    Last Post: 02-26-2016, 04:17 AM
  3. Suggestions - full screen tablet clock with weather
    By kilen71 in forum Android Apps
    Last Post: 02-20-2016, 12:46 PM
  4. how do I check voice mail on a galaxy s6 on AT&T?
    Last Post: 02-20-2016, 12:20 PM
  5. Lock screen will not unlock phone
    By CAElite in forum General Help and How To
    Last Post: 02-20-2016, 10:36 AM
