1. KingKhal's Avatar
    Bought a new tempered glass, front and back, but both not fit well. Front, on top and bottom doesn't stick nicely as the moddle part..... back, the size a bit smaller, it doesn't cover the whole back panel. So, i removed it. Any suggestions of brand that fit well?
    03-13-2016 08:24 PM
  2. scott0121's Avatar
    Go onto eBay and type this item number in (231805589312), this sellers tempered glass screen protectors fit inch perfect and I use them on my S6 edge, hope that helps.
    04-10-2016 11:03 AM
  1. s7 Edge getting hot - overheating?
    By xxstranger in forum Samsung Galaxy S7 edge
    Last Post: 11-06-2016, 11:40 PM
  2. Encryption s6
    By jleemess in forum Samsung Galaxy S6
    Last Post: 03-14-2016, 03:09 PM
  3. Fingerprint security timeout issue. Am in the only one on GS7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-14-2016, 12:14 PM
  4. S7 Edge Touch Sensitivity
    By mrohdem in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 10:00 PM
  5. Any bothered by glare of edge?
    By sfla99 in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 07:55 PM
