Originally Posted by
weston87 After recent update to marshmallow the fast charging has not been working. I'm with sprint. Any ideas how to fix?
Sent from my awesome S6 Edge!
Go into settings.
Battery option.
Scroll to the bottom.
See if Fast charging is enabled or not.
If not then enable it.
If it's enabled and still not fast charging, restarting the device might help. If not, replace cable and wall adapter and check.
If these things don't work then I don't know what's wrong. Sorry.
