1. AC Question's Avatar
    On my Samsung S6 Edge there is a shadow when pointing the finger on something. It is not everywhere present but when the background is a light color like white then when choosing something there is a shadow, you can see it well when holding the finger on a item the the shadow spreads.
    I find it annoying that the shadow is there, is there i possibility to turn off the shadow?
    It is a kind of mark to see that you choose that item but when i am put my finder on that item i know thats what i want...
    03-22-2016 06:29 AM
  2. anon(9408097)'s Avatar
    Go to settings.
    Scroll to the bottom.
    See if you can find developer options.
    If you do find it, press it.
    Find the 'show touches' tab
    Turn it off.
    If you don't find developer options.
    Enable it by going into about device and clicking on the build number several times.
    If this doesn't work then I don't know what's wrong.
    03-22-2016 04:08 PM
  3. cstrienen's Avatar
    Thx. This setting was already switched off but still have the shadows.
    03-23-2016 05:07 AM
  1. Is CM LAUNCHERS BAD TO USE ON TODAY'S ANDROIDS DEVICES?
    Last Post: 09-01-2019, 09:32 PM
  2. camera takes too long to load
    By mirnox in forum Ask a Question
    Last Post: 03-24-2016, 06:33 PM
  3. How do you save your settings on Samsung Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-22-2016, 03:43 PM
  4. s6 auto turn
    By aleksander232991 in forum Samsung Galaxy S6
    Last Post: 03-22-2016, 08:34 AM
  5. Replies: 2
    Last Post: 03-22-2016, 07:18 AM
