1. stewarta13wsb's Avatar
    Cordless charging.... after working great for the first few days it has now become almost useless to charge my S6 Edge +. It keeps getting a flashing blue light. The phone says charging paused.
    Sometime it restarts, sometimes it doesn't, so unless I'm watching it, when I come back I have an uncharged phone.
    I've unplugged it and tested the fast charger and it works fine. The first time I plugged the pad back in it seemed OK but has failed since. Placement seems ridiculously critical and even when it looks good, and starts charging, it soon stops. The Amazon site I bought it from says ask Samsung! Not very helpful!
    Any suggestions on here?
    04-13-2016 06:22 AM
  2. enduro's Avatar
    I have the Samsung wireless charger too but don't share your problem.
    If you have a cover on your phone try charging without that on. I've got a relatively thick cover and the charge goes through that but I have read that even some if the thin covers can cause wireless charge issues.
    I'd also be contacting Samsung about the issue. I think it's reasonable tmfor the seller to ask you to do that. Arrange a warranty fix or replacement with the seller if you think it is faulty.
    04-17-2016 12:00 AM
  3. enduro's Avatar
    I'm coming back to post again as I have just yesterday noticed the flashing problem you mentioned above. After cable charging and having the wireless charger disconnected for a while (several hours while I was at work) it seems to be wirking fine again. Having a thick case on the phone certainly makes a difference on how accurate one has to be when putting the phone on the charger.
    04-21-2016 05:52 AM
  1. My phone is plugged in, but won't connect to the charger.
    Last Post: 05-22-2016, 04:38 PM
  2. Why are adds showing up when I charge wirelessly on my Samsung S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-06-2016, 11:55 AM
  3. Replies: 2
    Last Post: 04-21-2016, 05:09 PM
  4. Wireless Charging?
    By erwaso in forum HTC 10
    Last Post: 04-15-2016, 10:53 AM
  5. Generic tablet charger
    Last Post: 04-12-2016, 10:10 AM
