1. Courtenay Dawn's Avatar
    I just recently got the update to Marshmallow 6.0.1, works fine but there was a lot of hype about the update, I don't really see anything new to it other than the inner works of it. I've noticed the pull down menu on my s6 edge is different along with the different things you can do with the edge screen, but other than that is there anything new? Usually they change quite a bit with new OS'S.
    04-18-2016 05:35 AM
  2. H3aTeRzz's Avatar
    Hi Courtenay!
    Found this video, Hope this helps! I don't have MM yet with AT&T, but am in no hurry to get it, till the initial bugs get worked out! :-D
    Chris
    Courtenay Dawn likes this.
    04-18-2016 06:19 AM
  3. anon(9408097)'s Avatar
    The feelings were mutual, when I first got the update. Give it time. It's been a month since I've been using this phone after the update. And it has completely changed my opinion about the phone and the OS.
    You'll notice gradually how fluidity affects the overall experience of using the phone. It's faster and fluid.
    Give it time.
    04-18-2016 07:00 AM
  1. Replies: 1
    Last Post: 04-19-2016, 03:18 PM
  2. Using Gear S2 and Gear S without the upgrading
    By mn42 in forum Samsung Gear S2
    Last Post: 04-18-2016, 06:58 AM
  3. Any Use For the MicroSD Card?
    By Murph5150 in forum Moto X
    Last Post: 04-18-2016, 05:37 AM
  4. Bootloader unlocked, now what
    Last Post: 04-18-2016, 05:27 AM
  5. Phone goes straight to bootloader
    Last Post: 04-18-2016, 05:19 AM
