1. Caden Barstad's Avatar
    okay when i turned on my phone the back and the tab button keeps flashing nonstop . Also if i try to swipe the screen whatever my thumb slides on it goes to that app, plus my phone is now really slow so it tried to reset the settings to see if that work but i did not and all i did was have the do not disturb setting on for my alarm on the phone all night. I'm wondering if that the case. Here's an other one it don't respond quick like to type i'm on my computer now cause it would take too long to type or even the tab and back buttons. I also have to move my finger slow cause i don't respond quick. So someone help me please if your can or had the same problem.
    05-03-2016 03:20 PM
  2. B. Diddy's Avatar
    Wecome to Android Central! Try booting into Recovery and wiping the cache partition: https://support.t-mobile.com/docs/DOC-21095
    05-03-2016 10:35 PM
  1. Replies: 1
    Last Post: 05-15-2016, 10:54 AM
  2. Replies: 2
    Last Post: 05-14-2016, 11:43 AM
  3. Replies: 1
    Last Post: 05-03-2016, 10:37 PM
  4. Will rooting my phone lock the carrier?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 05-03-2016, 05:08 PM
  5. Help T-Mobile Note 5 incompatible error on Pioneer 4100nex?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 05-03-2016, 02:44 PM
