1. dramastyle's Avatar
    okay all day my battery wouldnt charge for the samsung s6, its frustrating. now as its on the charger, the battery life is going DOWN. its at 3% again and i NEED this phone to not die. i have no idea what else to do!! i literally tried everything, shutting off apps, using anti virus cleanings, power saving. im out of ideas!!
    05-31-2016 08:57 PM
  2. srkmagnus's Avatar
    Are you using the wall charger? I would suggest trying another power source and/or charger - if you are not using OEM then use the OEM charger/cable that came with the S6. If that doesn't work then consider a factory reset - backup first - and see if that helps. It could be a software issue.
    Finally, if nothing works and you've tried new charging hardware contact Samsung support to see if they can help or provide you with repair options. I am going to move this to the S6 forums since it's more specific to the device hardware rather than a third-party battery (i.e. replacement battery or battery pack).
    05-31-2016 10:15 PM
  1. battery life suddenly terrible
    By dramastyle in forum Samsung Galaxy S6
    Last Post: 06-06-2016, 12:02 PM
  2. Replies: 3
    Last Post: 06-05-2016, 07:56 AM
  3. Replies: 1
    Last Post: 06-01-2016, 09:37 PM
  4. Why is my s7 not notifying me when I get text messages
    Last Post: 06-01-2016, 10:08 AM
  5. Why my webview app does not upload image from phone ?
    By Dere Ezekiel in forum Ask a Question
    Last Post: 05-31-2016, 07:29 PM
