1. AC Question's Avatar
    It keeps telling me the CPU is running in the background and it is overheating
    07-14-2016 05:33 AM
  2. TheGoodNamesAreGone's Avatar
    Try downloading something like Gsam battery monitor to see what might be doing that. Chances are if CPU is affected and the temp is up, battery is likely to be affected too. Also try running in safe mode , if it doesn't overheat in safe mode, an app may be to blame.
    07-14-2016 12:51 PM
  1. Android Wear Newbie - some (probably simple) questions
    By vaderag in forum Android Wear / Wear OS
    Last Post: 07-17-2016, 06:13 PM
  2. could android pay change cards' order in cardpool?
    By Changcheng Tu in forum Android Apps
    Last Post: 07-16-2016, 06:15 PM
  3. Is there a way to fix my S6 Edge cameras stuck pixels?
    By Yokonzo Cekki in forum Samsung Galaxy S6 edge
    Last Post: 07-15-2016, 03:03 AM
  4. Why doesn't my Samsung Galaxy S II wanna start?
    By AC Question in forum Samsung Galaxy S2
    Last Post: 07-14-2016, 09:46 AM
