1. AC Question's Avatar
    hi guys. i bought an s6 edge(SM-G925F),lollipop, from a guy like a week ago. and its rooted.so i want to update it to marshmallow and to get that i have to unroot it. i tried to do it using odin 3.10.6 and i downloaded the stock firmware two times from two different websites. odin failed both times.with the first firmware, it gave me an open serial com port error and with the second firmware,it gave me a NAND write start fail. what should i do?
    1-should i flash marshmallow?will it unroot my s6 edge?
    2-should i just try with odin(it tried like 5 times)?
    3-is there any way i can unroot it with supersu?(it was rooted through odin)
    i tried smartswitch too but it just doesnt show me the updates.
    please help!!
    i got to know of the odin method from this site: androidrootz
    btw i am from pakistan and can you tell me if my sims would work in the like usa or uk firmware. would installing some else country firmware fix the problem?
    thanks
    09-20-2016 02:44 AM
  2. AlphaTango414's Avatar
    Sounds like you don't have the right firmware for your device. Ensure its a G925F and not another model # (variant of edge) you can find that info under about phone in settings.
    09-20-2016 03:19 AM
  3. mirsab's Avatar
    no it is SM-G925F
    i have checked it and its the same
    09-20-2016 03:23 AM
  4. B. Diddy's Avatar
    Merged duplicate threads and moved to the S6 edge Rooting forum.
    09-25-2016 02:02 AM
  5. itguyjax8430's Avatar
    please help!!
    thanks
    Give this guide below a try, it will reset the phone back to factory after it downloads a fresh copy of the OS from Samsung.
    http://forums.androidcentral.com/amb...sung-kies.html
    09-28-2016 07:53 AM
  6. Tobym1982's Avatar
    All u have to do is go to sammobile.com and find the firmware u want and flash it via odin
    05-06-2017 07:26 PM
  7. ffejjj's Avatar
    Why not just flash the rooted marshmallow rom?
    05-06-2017 07:37 PM
  8. Tobym1982's Avatar
    If ur unrooting then u need the last up date u had best thing fo to 5.1 and sonce its unrooted it will update all the up to nougat, if u flash 5.1 u can upgrade then if u want to go back to 5.1 u can as if u were to juat flash the 6.0 u wont be able to go back any futher after that amd my s6 flat the keyboard is in a miiror affect from goung back after flashing just the 6.0
    05-07-2017 01:22 AM
  1. How I think the Note 7 should have been released
    By BlackZeppelin in forum Samsung Galaxy Note 7
    Last Post: 09-20-2016, 03:04 PM
  2. How do I unlock my S6 edge?
    Last Post: 09-20-2016, 02:10 AM
  3. Replies: 1
    Last Post: 09-20-2016, 01:35 AM
  4. Replies: 0
    Last Post: 09-20-2016, 01:31 AM
  5. Replies: 0
    Last Post: 09-20-2016, 12:41 AM
