1. Nadeesh Herath's Avatar
    After updating my S6 edge to 6.0.1 the fingerprint reader requires a pattern too to unlock the phone. Before installing this update i only needed to use the fingerprint to unlock the device where as now it does not prompt for the fingerprint at all times it needs a password/pattern. Is this a common issue for the 6.0.1 update? if not how can i resolve it?
    09-29-2016 05:47 AM
  2. anon(632115)'s Avatar
    It is a change that Samsung has introduced. You will need to set up your lock screen security again. I can get into all my devices just using a fingerprint but on reboot or if not used for 24 hours I have to input a password.
    There's good information here Changes on using fingerprint to unlock Galaxy S6 in Android Marshmallow update for Galaxy S6, S6 edge and S6 edge+ - Galaxy S6 Guide
    09-29-2016 06:30 AM
  3. BrutalhonestyM's Avatar
    Yeah it is a common feature for the MM 6.0.1 update and not an issue in particular. This feature which is also already available to IOS users has been implemented for your own security purposes. Unfortunately as far as I am aware you cannot turn it off as is it's there for a reason. You can be compelled to provide your fingerprint and unlock your phone, under current U.S. law (if they have a warrant) but you cannot be forced to enter your password. A precedent was set by the Circuit Court of Virginia in October 2014, and recently upheld and reinforced by a federal court in February 2016 that your fingerprint is not protected by the 5th amendmen
    altobobcat likes this.
    09-29-2016 06:52 AM
  1. S6 Battery Life?
    By Matthew 3 in forum Samsung Galaxy S6
    Last Post: 11-09-2016, 01:46 AM
  2. Why can't I get the Hangouts app to work on my HTC phone?
    Last Post: 09-29-2016, 12:41 PM
  3. Replies: 1
    Last Post: 09-29-2016, 12:10 PM
  4. Samsung Gallery
    By subguy812 in forum Samsung Galaxy Note 7
    Last Post: 09-29-2016, 11:31 AM
  5. Replies: 0
    Last Post: 09-29-2016, 05:45 AM
