1. incyt's Avatar
    Today I woke up and realized that my battery was draining unusually fast, even though I was not doing much on my phone. Later, I tried to watch a youtube video and the video kept pausing, even though it was loaded and not a connection problem. I tried downloaded videos on my device, and even those were lagging. My phone was in my pocket, but it vibrated for no reason, and later it gave me a message that my samsung pay card was deleted because of too many wrong attempts, when I didn't even try to use it once. When I went to charge it, the charging was extremely slow, even on my fast charger. I had no other apps open, and to my knowledge no background apps. This all started today, and I have no idea what is going on, help would be greatly appreciated.
    Edit: Thought maybe wifi calling was the issue, so tried to turn it off, but it just keeps loading and I can't...
    09-30-2016 12:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you already tried wiping the cache partition? https://support.t-mobile.com/docs/DOC-21095. Or seeing if these things happen in Safe Mode? https://support.t-mobile.com/docs/DOC-29226
    10-02-2016 02:58 AM
  3. buzzard's Avatar
    My S6E had been running hot the past few days (which also means the battery is draining fast). Didn't start until the latest update in AT&T. Not sure if WiFi calling is the culprit (though I have it turned off). I will try wiping the cache partition to see if that helps.
    10-08-2016 10:43 AM
  4. buzzard's Avatar
    No improvement after wiping cache partition. Depleted battery nearly twice today.
    10-09-2016 10:49 PM
  1. how's your s7 edge holding up?
    By victoryrules8 in forum Samsung Galaxy S7 edge
    Last Post: 10-08-2016, 02:20 PM
  2. Galaxy S7 Edge messaging issues!
    Last Post: 09-30-2016, 01:14 AM
  3. Why is the microphone on my Galaxy S7 only picking up static?
    Last Post: 09-30-2016, 01:11 AM
  4. Replies: 1
    Last Post: 09-29-2016, 10:09 PM
  5. How to disable sos feature from galaxy note 4
    Last Post: 09-29-2016, 09:35 PM
