1. Adam Vesnaver's Avatar
    Hi there. So I bought a brand new unlocked Samsung s6 edge from the Samsung store in Australia and have very very poor cell service and data service. 90% of the time I won't be able so sent texts, use data. 3 telus staff members and one Samsung staff member have looked at it but have had no luck in fixing it. I was hoping someone on these forums would have a solution. Thanks very much in advance!
    Adam
    04-08-2017 09:43 PM
  2. Tim1954's Avatar
    You may find they use different frequency bands in Canada. Unlocked doesn't mean region unlocked, specifically, the device needs to work on the frequencies that are used in the region it's manufactured for. The model number will tell you the frequency bands your device works on, and a quick google search on Canadian bands will provide you with the ones in use there. Compare the two and you'll have your answer.
    04-09-2017 06:02 AM
  1. Where Is Download Manager Icon On Samsung Galaxy S6
    Last Post: 05-09-2018, 06:41 AM
  2. GAME TOOLS floating button showing up in WHATSAPP
    By vamsiguduru in forum Samsung Galaxy S7 edge
    Last Post: 04-12-2017, 04:44 PM
  3. Moving contacts saved to my Samsung S6 Active device over to Google
    By AC Question in forum Samsung Galaxy S6 active
    Last Post: 04-09-2017, 02:48 PM
  4. Why isn't my tablet's Wi-fi working?
    Last Post: 04-09-2017, 02:46 PM
  5. Phone keeps uncharging and charging even though plugger in
    Last Post: 04-09-2017, 04:23 AM
