Device Idle
averen09
Active member
Nov 27, 2015
39
Guys, whats with device idle? Why its always the second most battery hog on my batteru usage list? Im on s6 edge running nougat.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,168
4,273
113
It'd be helpful to see more battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
averen09
Active member
Nov 27, 2015
39
by the way, im a new member here, how do i post images on the forums, currently im using android Central app from playstore to browse the forums
