1. LilaP's Avatar
    I rebooted my phone last night and when it turned back on all of app icons are huge.
    I have a Samsung S6 Edge Curve.
    Can someone plz help me to get them back to a smaller size?
    Thank you
    Below you see the screenshots on how big they are in the first shot
    Second shot I have no idea where those came from. Might be an app I had downloaded, but don't remember the name of it and there are no more strange apps in my settings. when I put my cursor over the head of one it says add a contact.
    08-08-2017 09:32 AM
  2. Javier P's Avatar
    It's possible that easy mode was enabled. Try switching back to standard mode in your general settings.
    08-08-2017 10:02 AM
  3. LilaP's Avatar
    where the heck do I find the easy mode? I looked and I cannot find it...tyvm
    Its ok I found it.. I did a search in my settings. back to normal now...tyvm for you help
    Javier P likes this.
    08-08-2017 10:20 AM
  4. Javier P's Avatar
    Glad it helped! Please, tell us the whole path to turn easy mode off in your phone. This will be very helpful for other users with the same issue.
    08-08-2017 10:29 AM
  5. LilaP's Avatar
    To find my easy mode...I went into my setting and did a search for easy mode and it came up so I clicked on it and that is how I found it.
    08-08-2017 10:35 AM
  1. Replies: 10
    Last Post: 12-01-2018, 02:07 AM
  2. Can't slide pictures on my folder
    Last Post: 08-11-2017, 01:01 PM
  3. Galaxy s7 will not let me log into my Google account.
    By AC Question in forum Samsung Galaxy S7
    Last Post: 08-11-2017, 11:50 AM
  4. i can't get my Galaxy 6 phone to sync to my 2013 ford fusion.
    Last Post: 08-08-2017, 01:15 PM
  5. Replies: 0
    Last Post: 08-08-2017, 09:17 AM
