1. chris gamble's Avatar
    I own a Samsung galaxy s6 edge and I've been having a problem with it. Whenever I would want to plug it in to charge the power button would stop working and if I pressed the home button or moved my cord it would automatically boot me to the internet app. The only buttons working are the volume ones. Does anyone know what the problem is or what has caused it? This is my second phone and I don't want to replace it again.
    08-09-2017 03:59 PM
  2. Tim1954's Avatar
    First thing to do when you have any issues is cache partition wipe.
    If you still have issues, I'd dial *#0*# to get service mode and check out the hardware.
    If you only have issues with charger plugged in, you might want to try a different usb cable...
    08-09-2017 06:58 PM
  3. WowSpring6's Avatar
    pls change another charging cable to have a look whether it is the problem of teh cable.
    08-10-2017 04:32 AM
  1. Why çant i screen shot on sports betting apps
    Last Post: 08-10-2017, 02:06 PM
  2. How do you get the vanishing navigation bar to stay visible?
    By PaulQ in forum Samsung Galaxy S8 & S8+
    Last Post: 08-09-2017, 04:44 PM
  3. Replies: 1
    Last Post: 08-09-2017, 03:56 PM
  4. Why won't my s6 charge
    Last Post: 08-09-2017, 03:53 PM
  5. Why is my root directory 85% full?
    Last Post: 08-09-2017, 03:29 PM
