1. Dr Asaad's Avatar
    Actually ive not its original charger . I charged it with 2 3 chargers but it gives me poor battery time . Then i bought original charger of hp with 3amp . It gives me 3 hours continuous usage with remaining 56% battery . Then i slept and when i woke up its standby consuming battery with wifi on is 16% which means it was on 40% . I want to ask that if it is normal ??
    09-07-2017 01:24 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    09-07-2017 04:03 PM
  1. How to do factory reset when you've forgotten Samsung account password
    By ruby2zday in forum Samsung Galaxy S7 edge
    Last Post: 08-10-2018, 03:49 AM
  2. Replies: 12
    Last Post: 12-18-2017, 12:41 PM
  3. Replies: 4
    Last Post: 09-26-2017, 05:37 PM
  4. Replies: 1
    Last Post: 09-07-2017, 04:08 PM
  5. Can I block my own cell number?
    By iamihop in forum Motorola Droid Turbo
    Last Post: 09-06-2017, 11:30 PM
