My s6 edge was dropped in toilet. I had camera and charging issues so changed charge port, battery and rear camera. Also I wiped the cache and tried in safe mode. It's charging ok now but I keep getting camera fail. Can anyone please help?
The reason why the camera is failing almost certainly has to do with water damage. You would most likely have to get the camera module replaced, but that wouldn't guarantee that it would work, since there could be other components that are also corroding from the water exposure.
