1. Jiteshajaria's Avatar
    My Galaxy S6 Edge's screen is showing Straight Vertical lines of various colours. Will Samsung replace it for free or give any kind of diacount or Compensastion. I have been using S6 Edge from a long time. I am screwed up .How to fix it and the new screen is too expensive and I am confused what to do?
    01-29-2018 12:38 PM
  2. SpookDroid's Avatar
    Unfortunately unless the device is still under warranty and the repair shop diagnosis doesn't show any tampering or physical damage to the phone, Samsung will not replace your screen or device for free.
    Do the vertical lines stay fixed or do the 'jump'? Does it fix itself after a while? What about if you press (gently) on the edges of the phone? If the latter works, it might just be a loose connector and not something that requires the entire screen to be replaced.
    Jiteshajaria likes this.
    01-29-2018 12:55 PM
  3. Jiteshajaria's Avatar
    Unfortunately, they stay fixed and are increasing day by day.
    01-30-2018 01:09 AM
  4. SpookDroid's Avatar
    If they're over anything else on the phone (any app), then that spells hardware issue, and most likely, a display panel one. It could still be a faulty connector (cheaper to repair than a screen) but I wouldn't keep my hopes up.
    01-30-2018 11:34 AM
  5. Rukbat's Avatar
    Of they're spreading, it's a physically broken screen, and it has to be replaced. Unfortunately, that kind of breakage is usually caused by dropping the phone or keeping it in a tight pocket, so it's not covered.
    01-30-2018 02:51 PM
  1. Is the BlackBerry KEYone still worth buying?
    By jd4d in forum BlackBerry Android Phones
    Last Post: 08-03-2019, 11:41 PM
  2. Galaxy note tablet
    Last Post: 05-19-2018, 01:36 PM
  3. galaxy s8/s8+ android oreo update.
    By pimdiddih in forum Samsung Galaxy S8 & S8+
    Last Post: 04-04-2018, 11:01 PM
  4. How to factory unlocked galaxy s8+ T-mobile?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 02-01-2018, 09:27 AM
  5. Why would my galaxy S5 just stop letting me send texts but still receive fine??
    Last Post: 01-29-2018, 01:00 PM
