Hello!
I have a Samsung Galaxy S6 Edge (SM-G925F). The problem is that the battery is draining very fast if I am using the phone. Firstly i thought it was the battery, but after a replacement with a genuine one the problem still persists. My battery drains in 3 hrs if I am using the phone only to stay on social media and type. I tried a factory reset, cache wipe, another firmware install, disabling apps, using the power save mode, but nothing helps!
Does someone know how to fix this?
