1. virusdorw21's Avatar
    Hello!
    I have a Samsung Galaxy S6 Edge (SM-G925F). The problem is that the battery is draining very fast if I am using the phone. Firstly i thought it was the battery, but after a replacement with a genuine one the problem still persists. My battery drains in 3 hrs if I am using the phone only to stay on social media and type. I tried a factory reset, cache wipe, another firmware install, disabling apps, using the power save mode, but nothing helps!
    Does someone know how to fix this?
    04-23-2018 02:52 PM
  2. Rukbat's Avatar
    Screen brightness? Screen timeout value?
    Mobile data or wifi strength?
    Total screen on time after 3 hours?
    04-23-2018 03:11 PM
  1. Smartphones with easily replaceable internal battery
    By uraniumhexoflorite in forum Ask a Question
    Last Post: 04-24-2018, 02:12 PM
  2. Best Samsung Galaxy S9 Plus battery case
    By jimjonesG7 in forum Samsung Galaxy S9 & S9+
    Last Post: 04-23-2018, 03:13 PM
  3. S6 Edge - Battery drains fast
    Last Post: 04-23-2018, 02:51 PM
  4. Best Samsung Galaxy S9 Plus battery case
    Last Post: 04-23-2018, 01:18 PM
  5. My Sound setting keeps resetting after a missed call?
    Last Post: 04-23-2018, 12:07 PM
