    NORMAL REBOOT DOESNT WORK AND KEEP RESETTING AFTER THE INITIAL SAMSUNG WELCOME PAGE keeps rebooting Right after the first screen switches to the updating screen. I CAN ACCESS THE "WARNING SCREEN TO DOWNLOAD A CUSTOM OS"SO HOW DO I FIND A os to download and what steps do i take?
    05-21-2018 05:59 AM
  2. Golfdriver97's Avatar
    The custom OS screen is where you would use Odin to install any OS, even the stock one. You can try reinstalling the stock ROM, to see if you can get back up and running.
    https://forums.androidcentral.com/am...ml#post6196695
    05-21-2018 09:09 AM
  1. LG V20 - how to replace JUST the front glass?
    By enginestar in forum LG V20
    Last Post: 01-09-2020, 01:29 PM
  2. Replies: 4
    Last Post: 05-22-2018, 10:00 AM
  3. Galaxy Tab S3 9.7 stuck on "Android starting..." after latest update
    Last Post: 05-21-2018, 10:26 AM
  4. What happened to being able to schedule a text to be sent on S9+
    Last Post: 05-21-2018, 08:49 AM
  5. How to close this from my device
    Last Post: 05-21-2018, 05:20 AM
