    For some reason my Samsung galaxy s6 edge started losing battery life fast and on one night it stoped working. I tried charging it but it wouldn't charge ,it will only show the battery logo .I left it alone for awhile but it wasn't even showing any green so I tried to start it. On the internet it told me to system update it. The phone turned black right after and it flashed "system update" so I left it alone. After some time I checked on it by holding the home buttons, it flashed was flashing system update again and again but it stoped so I waited till the next day , I checked on it but it was still saying system update. I have no idea what to do
    07-22-2018 10:08 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What process did you follow for this system update? Is it showing a screen that says "Downloading, do not turn off target"?
    My suspicion is that your battery is failing, and that this doesn't have anything to do with a system update.
    07-24-2018 04:28 AM
  3. methodman89's Avatar
    Bad idea for any one to start a system update with a depleted battery.
    B. Diddy likes this.
    07-24-2018 05:46 AM
  1. how can i remove the exit that appears whenever i want to browse
    Last Post: 07-22-2018, 05:12 PM
  2. How do I get rid of the floating Dock button on the Huawei P20?
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 07-22-2018, 04:40 PM
  3. how it is possible?
    Last Post: 07-22-2018, 01:55 PM
  4. How does one dele an apple id
    Last Post: 07-22-2018, 01:38 PM
  5. How do I get rid of the floating Dock button on the Huawei P20?
    Last Post: 07-22-2018, 05:25 AM
