1. UrBoiEd762's Avatar
    I recently bought this phone to ditch my crappy old LG, but after a while of using it I realized that its all messed up. No matter how many times I try to calibrate my phone's gyroscope and compass its always going in the wrong direction. I've used the GPS toolbox app and the *#0*# method. Some one please help.
    07-27-2018 03:18 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Was the phone manufacturer refurbished, or did you get it used from a private seller? It sounds like a hardware issue. If the phone was manufacturer refurbished, it likely has a 30 day warranty (or a little more, if you're lucky) -- hopefully, you can take advantage of that. If you bought the phone from a private seller, you're probably out of luck, and would have to bring the phone to a repair shop.
    07-27-2018 06:13 PM
  1. DP5 - won't connect to WIFI
    By chenks in forum Android Pie
    Last Post: 07-30-2018, 03:51 PM
  2. The majority of all my basic android functions don't work. How do I fix this?
    Last Post: 07-27-2018, 07:54 PM
  3. Phone repeats my outgoing text
    By 1jimw in forum Google Nexus 5
    Last Post: 07-27-2018, 06:22 PM
  4. How to rollback my 10.or d from Oreo to Nougat?
    Last Post: 07-27-2018, 04:17 PM
  5. It's been a while
    By RaccoonOverLord in forum Android Games
    Last Post: 07-27-2018, 02:16 AM
