    If there are ANY PlayStore updates pending/available the battery drains extremely fast. Once I complete the pending/available updates the battery use returns to normal.
    12-27-2018 06:19 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it only while the apps are in the process of updating/installing, or does the battery drain even when it's waiting for you to tap the Update button? App installation can use a fair amount of power -- this is evident when setting up a new phone (or after a factory reset), when all of your apps are installing. The phone can get pretty warm, and the battery level can drop fairly quickly.
    12-27-2018 08:34 PM
  3. Rukbat's Avatar
    If you see the "download pending" notification, you're already updating one app. That would drain battery.
    12-27-2018 08:42 PM
  1. Desire Eye lagging when battery is charged 75% or more
    Last Post: 01-08-2019, 11:15 PM
  2. Why does my contacts are deleted themselves themselves
    Last Post: 12-29-2018, 08:13 AM
  3. How do I make "Ok Google" Work even when the screen is turned off on Samsung Galaxy J7?
    By Android Central Question in forum Samsung Galaxy J Series
    Last Post: 12-28-2018, 09:59 AM
  4. Replies: 1
    Last Post: 12-27-2018, 08:49 PM
  5. Replies: 1
    Last Post: 12-27-2018, 05:53 PM
