1. Uk420's Avatar
    Ive bought an s6 edge charging port off ebay after mine broke, the first one had a piece loose, so I told the seller and they sent me a new one. However this one is exactly the same! I want to know if this is an important component or just a sticky pad. I hope I can post a picture but if not; its a white square directly below the connector that connects to the main board, it completely detatched itself.
    I'll try and show you.
    If its just a sticky pad I'll use it and reassemble the phone.
    Thanks
    Update: cant add photos 🤦*♂️
    02-15-2019 06:51 AM
  2. Uk420's Avatar
    Thanks
    It's actually a black square with a white peel off paper protector.
    02-15-2019 07:00 AM
  1. Why am i not accessing my keybord on the screen techno s6s
    Last Post: 02-14-2019, 07:15 PM
  2. Screen mirroring not working on Galaxy S6
    By Android Central Question in forum Samsung Galaxy S6
    Last Post: 02-14-2019, 04:38 PM
  3. Screen mirroring not working on Galaxy S6
    Last Post: 02-14-2019, 03:25 PM
  4. Replies: 2
    Last Post: 02-14-2019, 02:39 PM
  5. what do i do to turn on my screen and to remove voice assistant on S6 edge +?
    By Android Central Question in forum Samsung Galaxy S6 edge+
    Last Post: 02-13-2019, 03:49 PM
