1. Rog21's Avatar
    Hello all.
    I was having some issue with Galaxy S6 slowdown so I did a factory reset. I am on Android 5.0.2.
    After the factory reset was complete, when I tried to install any app, it would say it doesn't have enough space. When I checked the storage, I was shocked that out of 32 GB, 31.02 GB is reserved by system memory.
    Anyone know how to fix this? No matter how many times I factory reset it, it still takes 31.02 GB. Please check the attachment.
    If it's an issue with Android, can I upgrade to Android 6 and if there is a workaround for that since when I check for auto update, it says, I have the latest version.
    08-11-2019 01:33 PM
  2. Rukbat's Avatar
    There's something wrong there. Since you have nothing on the phone to lose, flash the stock ROM - [Samsung] How to flash Stock ROM via ODIN.
    And see [Guide] Storage is Missing to get a true idea of what's happening in storage.
    08-11-2019 02:41 PM
  3. Rog21's Avatar
    Can you please point me to the firmware for my phone?
    Since I have 5.0.2, which firmware should I install?
    My phone is rooted and has bootloader unlocked.
    08-11-2019 03:03 PM
  4. Rukbat's Avatar
    1. If you want rooted firmware, go to XDA Forums. Samsung firmware doesn't come rooted.
    2. It depends on the exact model number of the phone - G920F, G920FD, G920FQ, G920I, G920A or G920T?
    Then it may depend on the country and/or carrier. Go to https://www.sammobile.com/devices/ and put in the device number (or put in s6 and choose the device).
    08-11-2019 03:47 PM
  5. Rog21's Avatar
    My phone is ATT G920A.
    I tried searching for the firmware but there are too many options and not sure if I am in the right direction.
    Can you please share the link to rooted firmware and do I go with Android 6 or 7?
    08-11-2019 04:55 PM
  1. Taking screenshots on a Samsung Galaxy A7 (2018)
    By Fulani Filot in forum More Samsung Phones
    Last Post: 08-17-2019, 07:59 AM
  2. My Samsung galaxy s8 showing All folders in left corner of gallerys each folder.
    Last Post: 08-11-2019, 03:57 PM
  3. How do i decide where my music is dotted on my galaxy s9
    Last Post: 08-11-2019, 09:20 AM
  4. Why do I keep getting a "memory full" pop up on my s10e?
    Last Post: 08-11-2019, 07:41 AM
  5. Galaxy Watch doesn't display phone app when receiving call
    Last Post: 08-11-2019, 06:32 AM
