Couple things that "bother" me:
I get the battery in both devices are NOT removable (similar to the iPhones).
Even though the S6 & S6 Edge come in three different internal memory sizes, (if I'm not mistaken, ranging from 16 gb to 128 gb), there is no spot for an external SD card.
With this being said, I'm going to chaos the phone with the most internal memory (128 gb, if available on the AT&T network). I am not worried about the battery life because I also read Morphie is coming out with an external battery for the phone, which I'm going to invest in.
I'm still debating on which one, the S6 or S6 Edge. I'm going to have to see and play with them, then decide. My only question for everyone is since both will be running Lollipop 5.0 & up, will you be updating your current devices to run Lollipop 5.0 before the S6 or S6 Edge are released or do the update then upgrade?????
