1. ragdeiii03's Avatar
    How long does the battery last? Not everyone upgrades to a new phone every year. By the s6 battery being non-removable it assures Samsung that you will upgrade more frequently. Dead or faulty non-removable battery(new phone). Dead, faulty removable battery(new battery)...
    03-07-2015 07:48 AM
  2. clevin's Avatar
    on a charge? nobody has comprehensive test yet, but I would be surprised if its not as good as s5. GSMArena has excellent battery test, check there when the phone is released.
    aging over time? I heard sammi made effort to reduce heat in the system, which will help slow down aging somewhat. No way to tell until somebody actually do a year-long test (like I did for my Note 3 http://forums.androidcentral.com/sam...reference.html ).
    when battery dies, or when it holds significantly less charge, sammy suggests you send the phone to service center for battery replacement, probably cost $70-100. You can DIY, but it would not be easy and run some risks.
    03-07-2015 07:57 AM
  3. ibcop's Avatar
    With the improvements on the processor and other stuff, the S6 battery should surpass the S5 battery. Longevity is another matter and that won't be known for some time. The tear down videos will come soon enough to show how to replace the battery when the need comes.
    03-07-2015 08:02 AM
  4. Inders99's Avatar
    Agree, much to-do about nothing.
    ibcop likes this.
    03-07-2015 08:03 AM
  5. ahj4513's Avatar
    S6 battery, when plugged into an S5 will have shorter discharge time. I think Samsung achieves the S6 battery life by controlling the power consumption of the CPU (power optimization of exynos processor). Newer RAM type and storage type could also be contributing to less power consumption. They could have also improved the power consumption of the OLED panel.
    Sent from my SM-G920F using Tapatalk
    03-07-2015 01:12 PM
  6. clevin's Avatar
    There are obviously things in s6 that improves battery life (on a charge), there are also things in it that decreases the battery life.
    Its most likely gonna be better than s5, just because pushing it with worse battery would be unfathomable. The real question is how much better? Thats the information we can't get until test is done.
    03-07-2015 03:02 PM
  7. smooth4lyfe's Avatar
    03-07-2015 03:20 PM
  8. clevin's Avatar
    This is what Samsung is alleging, which is not bad at all
Name:	Screen Shot 2015-03-07 at 4.19.16 PM.png
    Battery life comparison: Samsung Galaxy S6 vs Apple iPhone 6 vs iPhone 6 Plus
    lol, those numbers are straight from official brochure. I would not trust them.
    03-07-2015 03:24 PM
  9. jcp007's Avatar
    We'll know when the production unit test results leak out. Field testing videos should pop up soon.
    Posted via My Samsung Galaxy S4 Handheld Device
    03-07-2015 03:30 PM
  10. ahj4513's Avatar
    The total capacity being lower doesn't necessarily mean worse battery. They could IMPROVE the battery itself in order to have more efficient charging. Studying battery can be both confusing and frustrating at times. Electrochemistry is a hard subject.
    03-07-2015 04:23 PM
  11. clevin's Avatar
    true, everything could happen, its useless guessing right now, we should really just sit back and wait for the test.
    03-07-2015 04:28 PM
  12. ilordvader's Avatar
    Thats is what I belive too
    just wait till its out & we will know
    03-08-2015 09:58 AM
  13. jcp007's Avatar
    I agree. It would "appear" that all improvements seem to indicate that the internal battery is sufficient. We should react only when we have real results and then we vote with our wallets instead of posting incessant rants. Purchase it or pass in favor of the GS7.
    03-08-2015 11:21 AM
  14. ilordvader's Avatar
    We need a Power Bank
    I got iWalk it charges 2.5 times
    READ DETAIL IN INFO
    05-12-2015 10:13 PM
  1. Switch to t mobile from verizon question
    By srfoot in forum Samsung Galaxy S5
    Last Post: 03-08-2015, 12:52 PM
  2. Galaxy S6 Back cover and Battery IS REMOVABLE
    By smooth4lyfe in forum Samsung Galaxy S6
    Last Post: 03-07-2015, 03:14 PM
  3. Nexus 5 white battery cover?
    By Ezzat Al Omari in forum Nexus 5 Accessories
    Last Post: 03-07-2015, 07:14 AM
  4. Replies: 1
    Last Post: 03-07-2015, 06:47 AM
  5. battery gets wet and damage?
    By wacomer in forum Samsung Galaxy S4 Mini
    Last Post: 03-06-2015, 10:33 PM
