Yep, and sadly, this should be end of discussion until the embargo is lifted
I don't think the S6 has one since everyone is showing / talking about it.
There's a very good chance this phone ends up with just average-slightly above average battery life for most people, but on the plus side, there are now at least 2 sites that claim it has outstanding battery life. Whoever uses their devices similarly to the way these couple sites test their devices are going to be very happy!
If it wasn't for the GSM Arena rating, the general consensus on the device right now would be that battery life is very good. Let's all hope GSM Arena's rating was wrong!
Samsung does have an embargo. It's set to lift early April.
It's just that all the reviews out so far are praising it to high heaven, so why in the world would you want them taken down?
I am not finding anywhere about an embargo. I could be wrong .. but searching around I am not finding anything about it.
na, GSMarena's rating is the only one so far make sense, the french review showing 75% better score is for CPU power efficiency, rather than common task battery rundown, which usually include web, video, talk, and don't stress cpu that much. The OP's battery chart doesn't even include s5, so no comparison is made here at all.
I think more realistic hope right now, is not GSMarena being wrong, rather, is somehow sammy can work hard and push out a 0-day patch to improve battery performance to be closer to s5 than it is now. I think its doable.
Even if we take GSMarena number as is for now, still the issue is they are comparing it to S5 after Lollipop update. If I remember correctly, it was like 72 endurance rating with KiKat. Then they retested it with Lollipop not too long ago and bumped it up almost 10. Maybe they did it correctly according to their way of calculating it with stand by/talk time though they don't reveal what carrier version.
But reality is that most S5 owners don't see much battery improvement with Lollipop if at all and often rather worse battery life, at least here in US. So if I take that into consideration, difference between S5 and S6 is not that big as they make it sound like.
After hearing about how the S6 is 'more efficient' whether it be the screen (even though its so high end) or processor or other parts, how will this efficiency effect the battery life? Maybe the battery will be better than people think if it is truly a more efficient phone hardware wise
What's more concerning is the possibility that every flagship this year might have worse battery life than its predecessor.
The S6 will not suffer as much and if nothing else changes, its battery life is still very close to S5's battery life figures (Which are phenomenal).
The other flagships aren't fairing so well. The G Flex 2 and the M9, from current results, are significantly worse than their predecessors.
The problem comes from the reference 64-bit ARM core that is apparently very power-hungry.
Samsung is using an efficient fabrication tech to help them achieve more efficiency than Qualcomm's SoC, but even then, the the power consumption of those ARM cores are way too much.
Next year should be a lot better once Qualcomm and Samsung go with their own custom cores.
Battery results are so subjective and depends upon the type of users, devices settings, users habits, how resource intensive apps are, and are apps running the background while heavy duty tasks like gaming, web browsing, social media, watching movies , listening to music, texting, email and calling. All,these things we do to different degrees and have different preferences. There will be no battery review that is more important than the one you do yourself. The GS6 battery results, absent earth shattering news, are not going to sway my purchase or pass decision about the device.
Yes, but in every measure of battery life (Stand-by, talk-time, web-browsing, Video playback), this year's flagships all seem to be inferior to their predecessor.
For the S6, it's not as severe and is only very slightly worse than the S5 by a few minutes.
For the G Flex 2 and M9, you're looking at an across the board 20-50% cut in battery life in all 4 metrics.
True, battery life is different depending on the type of user you are, but the results look like the battery lives will be WORSE no matter WHAT type of user you are.
If you're the type of person who barely uses his phone, the battery will still be worse because stand-by time is worse.
If you like to stream and browse the web often, the battery will still be worse because web-browsing time is worse.
If you like to watch videos, the battery will still be worse, because video playback time is worse.
If you're a mixed user, the battery will still be worse, because everything has worse battery life compared to the previous models.
This is what's concerning.
For the G Flex 2 and M9, you're looking at an across the board 40-50% cut in battery life in all 4 metrics.
How do you guys do your own battery tests?
Do you just take advantage of your carriers 14 day returns policy?
I think most flagships will continue the trend of putting bigger batteries in their phones each year like every company does. Samsung is the only one I've ever seen or heard of that has put a smaller one in. If the S6 battery life isn't very good then I think they missed the opportunity to really lock down the Android industry this year. But they had to be a tenth of a mm thinner than the iPhone. I wonder how many tenths of a mm increase there would have been if they put in a 3000 mAh battery. Half a mm maybe? Look at a ruler. I don't know anybody in the world that wouldn't take that.
Good points all. However, if you have these concerns now, then may be the GS6 is not for you. Take as a given that a smaller battery has the potential to adequately power a much better device. If it at least meets last year, then I am fine. My personal, first hand experience is what makes my mind up. Right now there is not enough from a battery perspective to sway my decision. As it is the least of my worries, am looking for other issues that may arise that are more of a priority. The market segment that truly is influenced enough to have doubts or pass on the deivce because of the battery and the storage issue is a shrinking one at best. Otherwise, it might have made it into the GS6.
For what it's worth... I just got back from BestBuy and was testing both the standard and edge S6. The regular S6 had been unplugged for 4 hours and had a screen on time of 1:40 and still had 75% battery on it. That's putting it around 6-7 hours of screen on time if that held up.
I made sure it had not been plugged in and checked all the battery stats and was pleasantly surprised.
FYI - The Samsung rep told me Samsung directly told him to expect 17-19 hours of standard daily use. Obviously usage time depends on the user but all the evidence I've seen points to a very respectable to possibly great batter life. Finger crossed!
