1. felloffthetruck's Avatar
    God I hope not but think I saw something about that 2.5D screen somewhere.
    What ya think?
    03-25-2015 05:22 PM
  2. iLLusive's Avatar
    Hmm not sure what you mean I put on tempered glass screens protectors, almost every day just fine on the Note 4. Do you actually have the device and have tried to get one put on unsuccessfully? Gadget guard makes one I personal use the Alpha glass from Otterbox.
    03-25-2015 09:04 PM
  3. felloffthetruck's Avatar
    Yes, it's impossible to find a perfect fitting Tempered glass for the Note 4. I just hope the S6 does not follow suit.
    03-27-2015 09:29 AM
  4. iLLusive's Avatar
    I have had no issues with Black Ice edition of Gadget guard and again....we install these nearly every day or two. Put on at least 30 myself on Note 4 with no issues and they fit perfect and work with all types of cases. Unless your expectations of perfect fitting are different then the rest of the world I am not sure what the issue is.
    03-27-2015 10:26 PM
  5. itsnotmeitsyou's Avatar
    The edges of the Note 4 are slightly curved (2.5D) and tempered glass screen protectors are flat. That is and always has been the issue. Some manufacturers made the glass protectors smaller so they didn't hang over the curved edges. Many cases will cover the resulting gap enough where it's not really noticeable.
    03-27-2015 11:11 PM
  6. iLLusive's Avatar
    No tempered glass screen protectors that I have ever seen cover the WHOLE glass. Guess that is why my expectations of them being very close to the edge..or the edge of the curved is normal expectation. To each their own but I just do not need hardly anything in the tempered line models doing what I guess a few people are seeing as "perfect fitting".
    03-27-2015 11:16 PM
  7. itsnotmeitsyou's Avatar
    Look up" halo effect" pictures of these protectors on the Note 4 before they started making them smaller. If you aren't bothered by the gaps, that's great. But many people are. On my Note 3, the tempered glass protector left about 1/8" between the trim. Almost an edge to edge fit.
    Edit: added a picture
    03-27-2015 11:19 PM
  8. iLLusive's Avatar
    Are you using like an amazon brand? Or was is Gadget guard or Alpha glass from Otterbox? I guess I have never had access to all brands out there so many my experience is just of what I believe is a higher quality brand. I will have to take a look as the Note 4 I have my desk tomorrow and look closer at the edge maybe my Otterbox made it feel different for me.
    03-27-2015 11:22 PM
  9. itsnotmeitsyou's Avatar
    I added a picture to my previous post.
    03-27-2015 11:23 PM
  10. felloffthetruck's Avatar
    I have used every Tempered Glass protector for the Note 4 and they all have some degree of Halo.
    Including 3 different redesigns of the Zagg Glass and the Otterbox Alpha Glass (which I have on now).
    I'm just hoping the S6 is not as bad.
    03-28-2015 08:00 AM
  1. Turn off the Group messaging warning?
    By mellojoe in forum Samsung Galaxy Note 4
    Last Post: 04-21-2019, 09:41 AM
  2. Is there an app to record my work hours?
    By petrpuck in forum Android Apps
    Last Post: 05-08-2015, 04:23 AM
  3. Does FoxFi Wireless Wifi mode work on the Verizon Galaxy Note Edge?
    By Ismael Pulido in forum Samsung Galaxy Note Edge
    Last Post: 04-21-2015, 10:08 PM
  4. Replies: 1
    Last Post: 04-02-2015, 03:10 PM
  5. can't hear the caller on Galaxy 3....
    By hybucket in forum Samsung Galaxy 3
    Last Post: 03-26-2015, 07:43 PM
