04-20-2015 09:21 AM
131 12345 ...
tools
  1. Gothamoddisee's Avatar
    S6 edge in the charging position on the Duracell Powermat (iPhone 4S Edition). It works in this position on both sides.
    Samsung Galaxy S6 Wireless charger steal!-p1300516.jpgSamsung Galaxy S6 Wireless charger steal!-p1300507.jpg
    04-03-2015 11:58 PM
  2. smooth4lyfe's Avatar
    Just purchased 2. Anyone know what the size of the portable battery is?
    Its 1840mah
    Gothamoddisee likes this.
    04-04-2015 12:16 AM
  3. smooth4lyfe's Avatar
ID:	169513Click image for larger version.
    Does it magnetize to the mat like the portable charger does?
    Nvm, read previous posts and saw that it does a little bit
    04-04-2015 12:17 AM
  4. Nice N Sticky's Avatar
    Its 1840mah
    Damn that's pretty sad
    04-04-2015 03:30 AM
  5. Gothamoddisee's Avatar
    Just incredible, thanks so much for the How To STEVESKI07!
    04-04-2015 03:41 AM
  6. STEVESKI07's Avatar
    Awesome. I'm sure it works the other way too if you wanted to charge 2 devices, but this is the position that you said is easy to line up with the camera bump? Might be best for night time use this way to make sure you have it charging since I disabled the sound.
    Everytime I come here I'm tempted to order more but then I'd have so many that they'd end up in bathrooms.
    04-04-2015 04:24 AM
  7. Gothamoddisee's Avatar
    Ha! Yeah, I'm debating how nuts it is to buy a fourth. Pretty nuts. But....I keep discovering more uses for this thing. I realized yesterday that while it's not a perfect fit, the included case houses my iPod rather snuggly, and now I'm wirelessly charging my ancient (5yrs old) 64gb iPod.
    I wonder, has anyone heard that there is anything but a cosmetic difference between the Powermat packaged for the old Galaxy versus the iPhone 4?
    04-04-2015 04:39 AM
  8. Gothamoddisee's Avatar
    Oh, and yes you could bring the s6 around so that the camera catches at the lip on the opposite end, or turn it 90 degrees to charge two items at once. Though as you correctly surmised, the way pictured is the most "in the dark secure" method I've discovered to line these two beauties up.
    04-04-2015 04:43 AM
  9. STEVESKI07's Avatar
    I'm not sure I'm following your question. The chargers are the same it's just the cases are different. I've purchased both the Galaxy S3 and the iPhone 4 versions.
    04-04-2015 05:53 AM
  10. smooth4lyfe's Avatar
    Eh, its good for emergencies. I never thought I'd use it much but its actually pretty useful. It charges my Z3 from 13% to 45%
    Gray Area likes this.
    04-04-2015 10:47 AM
  11. Gothamoddisee's Avatar
    Isn't there at least a color difference (black & white) between the two? I wondered, if the differences went beyond the cosmetic. But it seems not.
    04-04-2015 11:16 AM
  12. hawkeye16qb's Avatar
    Received mine. It's a sharp looking product. I have an old iphone 4 I slapped the case on and charged. One irritant is when you pick up the phone the base lifts from the magnet.
    Nice looking and the battery pack is a bonus, even in the case the capacity is low. It's a nice little deal to have in an emergency.
    04-04-2015 11:40 AM
  13. STEVESKI07's Avatar
    Not that I can see and I have both versions. Edit: I meant that I have both the white and black versions and only difference I can tell is color.
    04-04-2015 11:41 AM
  14. DWS44's Avatar
    You can select between a black and a white version on the iPhone version page if you have a color preference. The white one is actually a dollar cheaper at the moment.
    04-04-2015 11:52 AM
  15. titans30dude's Avatar
    just went ahead and ordered a white one myself. Didn't even have to pay for it, used it with my discover points.
    04-04-2015 11:53 AM
  16. Gray Area's Avatar
    Got my 3rd one! The gs3 version!
    Posted via the Android Central App on my Galaxy S5
    04-04-2015 03:52 PM
  17. radisri's Avatar
    So has anyone used charged their S6 with a case on? Wondering if it will still charge the phone.
    04-04-2015 06:20 PM
  18. Nice N Sticky's Avatar
    It should, I've had a few phones now with wireless charging and they all work perfectly fine with a case on it.
    04-04-2015 08:16 PM
  19. STEVESKI07's Avatar
    I feel like I should apologize for this since everybody probably already owns more of these than they need....but they are $4 now....
    http://www.amazon.com/gp/product/B00...cUvbUpU4333890
    erasat and cohoman like this.
    04-06-2015 07:56 AM
  20. cohoman's Avatar
    http://www.amazon.com/gp/product/B00...cUvbUpU4333907
    Great find on an insanely cheap wireless charger! Note, it does say this is an "add on item" so you can't just order this single item alone. Also, be aware the wall wart power plug is pretty long, and can cover up at least two outlets on a power strip.
    04-06-2015 08:03 AM
  21. Jaycemiskel's Avatar
    That's not bad. Although I actually don't mind paying an extra 4 bucks for the portable charger to be included though. I'm so happy they put PMA charging in this phone too
    04-06-2015 08:13 AM
  22. STEVESKI07's Avatar
    Send me some type of prepaid envelope or box or something and I'll be happy to send you a few portable chargers for free. I don't plan on using mine.
    04-06-2015 08:31 AM
  23. erasat's Avatar
    http://www.amazon.com/gp/product/B00...cUvbUpU4334186
    Just got another one, for $4, I'll always find a use for it. FYI, the $4 price is an Add-On Price, so you really have to buy $25 or more in order to let you proceed to checkout, I had some things pending to purchase, so I bought everything together and it worked, just $4 for the wireless pad.
    Thanks.
    04-06-2015 10:04 AM
  24. biggbrother2's Avatar
    Thinking about picking up a couple of these. However, the only downside I can see is that it's a PMA charger, which has extremely low compatibility with most phones/devices, since most major phones seem ti use Qi. So if other devices that support wireless charging, chances are they won't be compatible.
    04-06-2015 12:31 PM
  25. Gray Area's Avatar
    True, but hey they are just 9.99 ☺ basically the price of your basic non-otterbox phone case. If 2yrs from now you upgrade and it no longer supports pma then at least your not loosing a big chunk of investment.
    However I do hope Samsung keeps with universal wireless support and don't dump pma later like SD cards etc...
    04-06-2015 01:08 PM
131 12345 ...
  1. Give me your opinion on the "White Pearl" Galaxy S6
    By felloffthetruck in forum Samsung Galaxy S6
    Last Post: 04-05-2015, 01:27 PM
  2. Replies: 31
    Last Post: 03-30-2015, 01:05 PM
  3. Essentials for S6
    By cardboard60 in forum Samsung Galaxy S6
    Last Post: 03-29-2015, 10:17 PM
  4. How can I get Google to upload my question on my Samsung S2?
    By AC Question in forum Samsung Galaxy S2
    Last Post: 03-29-2015, 09:00 AM
  5. How do I get a normal keyboard on my Samsung Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-29-2015, 07:52 AM
