1. biggbrother2's Avatar
    First of all, I've never been one to believe in all those "training the battery methods" but I'm curious enough to try them on my S6. Anyone have a particular method?
    I will say that I have charged it twice and it has completely depleted twice. Fortunately it charges very very fast.
    04-03-2015 08:42 AM
  2. Gray Area's Avatar
    I usually do 3 full depletion when I first get a phone, and that usually is it with li-po Batts. I've read and will be implementing the 20%-80% methods with the gs6e. They say that's the best range to keep your batt in. I've been doing it on my gs5 for a week now and I can see the benefits, not that it really last longer but it's quick charging and the slowest range for depletion. Previously my gs5 would deplete from 100-80 in 1hr but from 80-20 could take up to 15hrs! Depending on use. So their may be something to that method.
    Posted via the Android Central App on my Galaxy S5
    04-03-2015 08:47 AM
  3. clevin's Avatar
    Its called calibration. It doesn't do anything for battery, but it does give operating system a curve it can rely on to report more accurate battery levels.
    To do this, charge to 100%, drain to less than 10%. Charge again to 100%. You are done.
    Calibration probably is needed every couple of months.
    Gray Area likes this.
    04-03-2015 09:16 AM
  1. Recharging battery slower than ever
    By zimtuff in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-25-2015, 01:38 PM
  2. Does the S6 still have samsung wallet?
    By ballaonnabudget in forum Samsung Galaxy S6
    Last Post: 04-03-2015, 11:06 PM
  3. Replies: 1
    Last Post: 04-03-2015, 10:55 AM
  4. Had a play with the Samsung Galaxy S6
    By scgf in forum Google Nexus 5
    Last Post: 04-03-2015, 07:44 AM
  5. Replies: 1
    Last Post: 04-03-2015, 07:11 AM
