04-06-2015 10:50 AM
76 1234
tools
  1. onthecouchagain's Avatar
    Yes for T-Mobile. It is just a quick toggle to turn off.
    After you toggle WiFi Calling off from the pull down, can you customize that toggle to be removed from the pulldown menu?
    04-05-2015 01:38 AM
  2. D13H4RD2L1V3's Avatar
    The One M9's battery is a disappointment. It's bigger than the S6 but either the S6 has more than enough power-saving tricks up it's sleeve to sip less power or HTC's software is un-optimized like heck. The camera performance on the M9 in Auto mode is letting it down. Manual adjustments reveal that underneath all that software mess, it's a very capable shooter.
    I'm also pretty surprised at the S6's benchmark results on Antutu. If anything, that's MORE THAN TWICE the score my M7 gets. That Exynos 7 is monstrous.It also beat the LG G3 by a significant margin (the G3 scored 47k without any thermal throttling.)
    04-05-2015 04:46 AM
  3. clevin's Avatar
    you can rearrange any item on pull down menu.
    First, pull the menu down with two fingers, instead of one.
    First battery life and performance numbers with final/retail unit-screenshot_2015-04-05-06-05-34-1.jpg
    Click edit icon on top right.
    Drag the one you want to hide to the bottom.
    onthecouchagain likes this.
    04-05-2015 06:03 AM
  4. jcp007's Avatar
    It could possibly be firmware related but also the chipset could be a factor as well.
    04-05-2015 07:17 AM
  5. moviedude2k's Avatar
    I have had my tmobile edge since 3/31 and I have been getting 16-17 hours on a charge. 3-4 hours of screen time. Perfect for my uses.
    04-05-2015 10:12 AM
  6. quietkvj's Avatar
    Wait, does that say download booster? Have the carriers not locked this on the S6?
    04-05-2015 11:15 AM
  7. clevin's Avatar
    I don't know, this is not an s6 screenshot
    04-05-2015 12:15 PM
  8. STEVESKI07's Avatar
    Not everyone is having poor battery life. A guy on Reddit sent me this after I was skeptical of him saying he had good battery life:
    First battery life and performance numbers with final/retail unit-ix11txs.jpg
    First battery life and performance numbers with final/retail unit-bawgaak.jpg
    He said he's using auto brightness too. WiFi turned off completely
    04-05-2015 01:25 PM
  9. beatsandlife's Avatar
    This is awesome!
    04-05-2015 01:27 PM
  10. Adranalyne's Avatar
    That's encouraging.
    04-05-2015 02:26 PM
  11. Almeuit's Avatar
    There isn't a quick toggle for the download booster on the T-Mobile S6 (see below) but the option is there under more networks (see below also).
    Attached Thumbnails First battery life and performance numbers with final/retail unit-1428259513466.jpg   First battery life and performance numbers with final/retail unit-1428259519150.jpg
    quietkvj likes this.
    04-05-2015 02:45 PM
  12. edgefever's Avatar
    @almeuit..how's the battery going?
    04-05-2015 02:53 PM
  13. Almeuit's Avatar
    Not bad so far. As long as I disable wifi calling when I leave the house it seems to fix it. It just seems once enabled it causes a cell standby issue.
    I am loving the wireless charging at home.
    edgefever likes this.
    04-05-2015 03:32 PM
  14. edgefever's Avatar
    Is that just a T-Mobile feature?
    04-05-2015 03:36 PM
  15. onthecouchagain's Avatar
    Did everyone see this? From GSMArena: Update, April 3: We received a retail unit and re-ran the benchmark. The numbers improved noticeably compared to the initial tests with the pre-production unit.
    First battery life and performance numbers with final/retail unit-battery-test-s6-2.jpg
    04-05-2015 03:40 PM
  16. Almeuit's Avatar
    Yeah... And Sprint.
    04-05-2015 03:44 PM
  17. erasat's Avatar
    Have you tried also turning off VoLTE?
    04-05-2015 04:00 PM
  18. Almeuit's Avatar
    I haven't yet.
    04-05-2015 06:36 PM
  19. D13H4RD2L1V3's Avatar
    Remember when I said that I'll be genuinely impressed if the S6 gets past 4 hours of screen-on time?
    Now that I see it, I'm really impressed. Great job, Samsung! Managed to give a mediocre 2,550mAh battery impressive battery life.
    04-05-2015 11:59 PM
  20. John Kar's Avatar
    More like it's a bad sign for other 2015 flagships.
    Even the S6, with all the cutting-edge and energy efficient technology, only managed to squeeze out 5 hour SoT with 24 hour usage from the 14nm power-hungry ARMv8 cores. What makes us think that other flagships using the 20nm reference ARMv8 cores with even worse tech will do any better?
    I said that the M9 will have worse battery life than the S6, and I was correct. I'll also predict that the Z4, G4, and other 2015 flagships will have worse battery life than the S6.
    04-06-2015 12:05 AM
  21. syspry's Avatar
    Was this on LTE?
    04-06-2015 12:15 AM
  22. Love Divine's Avatar
    People regularly pushed 7-8 hours SOT with phones like the M8 and Oneplus One. My iPhone 6+ gets incredible battery life and absolutely ridiculous standby too. It sucks that the 2015 Android flagships are a step backwards here.The M9 does indeed seem to have horrible battery life compared to the M8.
    D13H4RD2L1V3 likes this.
    04-06-2015 12:26 AM
  23. neo905's Avatar
    If the Z4 comes out with a 3,400 mAh battery instead of the 3,100 mAh in the Z3 as reported with the same 1080p screen. It will crush the S6 in battery life S810 or not.
    04-06-2015 06:33 AM
  24. jcp007's Avatar
    Was this on LTE?
    Just for my own knowledge. Why would it matter? Different network but battery results would be in line on a proportional basis with results above?
    04-06-2015 06:38 AM
  25. Inders99's Avatar
    Shopping expensive stuff is always a rushed decision for many, if we cool down and wait, we will find that we really don't need new toys after all. lol
    Yup...going on 3 years with the GS3 and if it wasn't slowing down or getting glitchy I'd still hang on to it.
    04-06-2015 08:12 AM
76 1234
  1. Beta tester for pc and android apps+games
    By Josiah23 in forum Ask a Question
    Last Post: 04-04-2015, 05:39 AM
  2. Factory Reset: Backup with Helium?
    By encelle111 in forum Samsung Galaxy Note 4
    Last Post: 04-04-2015, 12:20 AM
  3. Messages Notification with Open Windows
    By dacop in forum Samsung Galaxy Note 4
    Last Post: 04-03-2015, 05:43 PM
  4. How do I add an ice number to my screen?
    Last Post: 04-03-2015, 05:14 PM
