Wait, does that say download booster? Have the carriers not locked this on the S6?
There isn't a quick toggle for the download booster on the T-Mobile S6 (see below) but the option is there under more networks (see below also).
@almeuit..how's the battery going?
Not bad so far. As long as I disable wifi calling when I leave the house it seems to fix it. It just seems once enabled it causes a cell standby issue.
I am loving the wireless charging at home.
Remember when I said that I'll be genuinely impressed if the S6 gets past 4 hours of screen-on time?
Now that I see it, I'm really impressed. Great job, Samsung! Managed to give a mediocre 2,550mAh battery impressive battery life.
More like it's a bad sign for other 2015 flagships.
Even the S6, with all the cutting-edge and energy efficient technology, only managed to squeeze out 5 hour SoT with 24 hour usage from the 14nm power-hungry ARMv8 cores. What makes us think that other flagships using the 20nm reference ARMv8 cores with even worse tech will do any better?
I said that the M9 will have worse battery life than the S6, and I was correct. I'll also predict that the Z4, G4, and other 2015 flagships will have worse battery life than the S6.
Was this on LTE?
Shopping expensive stuff is always a rushed decision for many, if we cool down and wait, we will find that we really don't need new toys after all. lol
It won't matter as long as their other devices were tested under similar settings which I assume they were. But I'm curious if these are LTE conditions because if not, those posted times will be lower for me if I buy oneJust for my own knowledge. Why would it matter? Different network but battery results would be in line on a proportional basis with results above?
