1. BAreEhD's Avatar
    I'm about to pick up my S6 from the post office. I'm assuming it'll come partially charged. What's the accepted best practise with initial charging? Should I fully charge it prior to first use, or should I deplete it a little further this evening (it's 7:00 pm here) and give it a full charge overnight?
    04-08-2015 04:27 PM
  2. clevin's Avatar
    doesn't matter, li-ion battery has no memory effect, plug and unplug anytime you want.
    For accurate report of battery % by the OS, do a calibration some time soon, i.e., next week, or in two weeks, or in three weeks, whenever you get to it.
    04-08-2015 04:30 PM
  3. droidguy1964's Avatar
    Yep.
    04-08-2015 04:42 PM
  4. PsychDoc's Avatar
    What he said.
    04-08-2015 04:43 PM
  5. BAreEhD's Avatar
    Thanks folks.
    Yup, this is a damn nice phone!
    04-08-2015 06:00 PM
  6. eak1570's Avatar
    One more question. Should I do the factory reset first? (To clean everything up)Or doesn't matter.. Thanks.
    04-08-2015 06:59 PM
  7. beatsandlife's Avatar
    How does one calibrate a battery?
    04-08-2015 07:03 PM
  8. clevin's Avatar
    people think a hard reset helps to straight out problems with major system update.
    Although I agree with it, this is a brand new phone, im unsure it will do anything. It doesn't hurt neither though.
    charge to 100%, use it to run battery down to below 10%, charge back to 100%.
    This is to produce a calibration curve for the system so it can report battery level accurately (system has to convert voltage to % numbers, correlation is not linear). It doesn't really do anything to battery itself.
    Calibration will become necessary every 30-40 charge cycles, or when you have a new battery.
    04-08-2015 07:20 PM
  9. Almeuit's Avatar
    Dive in. It may drop quick but.. It won't hurt anything.
    04-08-2015 09:22 PM
  1. Lollipop in the UK
    By Matthew Way in forum Sony Xperia Z3 Compact
    Last Post: 04-15-2015, 06:41 PM
  2. I am just blind right now
    By kyle.brown in forum Samsung Galaxy S6
    Last Post: 04-08-2015, 03:47 PM
  3. Can I copy a rom from one phone and install it in a dead one?
    Last Post: 04-08-2015, 02:57 PM
  4. cancel send in stock email
    By kyleresq in forum Android 5.0 Lollipop
    Last Post: 04-08-2015, 02:52 PM
  5. Is my New Nexus 5 proximity sensor dead?
    By AC Question in forum Google Nexus 5
    Last Post: 04-08-2015, 02:45 PM
