04-15-2015 09:05 PM
93 1234
tools
  1. codysanbor's Avatar
    Just letting mine sit on night stand
    No issues
    04-10-2015 10:48 PM
  2. codysanbor's Avatar
    Just turned WiFi off going back to work at 93% ill be at home around 7 am will post results
    STEVESKI07 likes this.
    04-10-2015 10:49 PM
  3. STEVESKI07's Avatar
    Going to sleep soon. Going to keep WiFi Bluetooth and all the normal stuff I kept on with my S3 and see how it goes.
    04-10-2015 10:54 PM
  4. edgefever's Avatar
    Me too ,these new phone days are exhausting.
    04-10-2015 10:56 PM
  5. STEVESKI07's Avatar
    04-10-2015 10:57 PM
  6. markymark's Avatar
    Wtf? Click image for larger version.
    Something is whack. You used 3% in 12 minutes, codysanbor used 6% in 7 hrs 47 min? Either you have some rogue app that is eating up your battery or there is a bad batch of phones. These battery stats are all over the place.
    04-10-2015 11:03 PM
  7. edgefever's Avatar
    Verizon GS6 has no cell stand by battery issues-1428725176722.jpg. Now my graph says time remaining..
    04-10-2015 11:07 PM
  8. codysanbor's Avatar
    I even have s health on lol
    Hd calling and enabled
    But I did turn off where Google sends error reports
    That thing killed every s series phone I had
    04-10-2015 11:08 PM
  9. markymark's Avatar
    Maybe that's the trick. How do you turn it off?
    04-10-2015 11:13 PM
  10. codysanbor's Avatar
    It ask soon as you set phone up
    Or go to applications and find services or something and uncheck a box
    I would have to search when I get off work at 7 am
    I know my m7 did same thing it was a. Wake lock and wifi was constantly scanning nothing it was pulling so much power it barely charged
    04-10-2015 11:16 PM
  11. markymark's Avatar
    Interesting...
    04-10-2015 11:20 PM
  12. codysanbor's Avatar
    Interesting...
    Yup I'm hoping I get a good 4.5 outta screen time
    04-10-2015 11:23 PM
  13. edgefever's Avatar
    Time to plug in, not bad for the first charge. I don't think cell standby hurt it.Verizon GS6 has no cell stand by battery issues-1428726406647.jpgVerizon GS6 has no cell stand by battery issues-1428726395871.jpg
    04-10-2015 11:27 PM
  14. Jaycemiskel's Avatar
    So this is my first day but this is what I have right now.Verizon GS6 has no cell stand by battery issues-uploadfromtaptalk1428726736814.jpgVerizon GS6 has no cell stand by battery issues-uploadfromtaptalk1428726746833.jpg
    Edit: something is screwy with Instagram, I've barely used it today but it's at the top. Cell standby is 7% and I've used WiFi for half the day.
    04-10-2015 11:32 PM
  15. markymark's Avatar
    Time to plug in, not bad for the first charge. I don't think cell standby hurt it.Click image for larger version.
ID:	170755Click image for larger version.
    I don't know...it looks like cell standby at up a third of your battery. Should be like 5%. Or less with your on screen time.
    04-10-2015 11:33 PM
  16. edgefever's Avatar
    I know it matches my usage, but my sot is good.Verizon GS6 has no cell stand by battery issues-1428727302749.jpg
    04-10-2015 11:41 PM
  17. edgefever's Avatar
    04-10-2015 11:44 PM
  18. f308gt4's Avatar
    For the life of me, I can't figure out where I set this. If you can let us know it would be really appreciated.
    04-11-2015 12:09 AM
  19. codysanbor's Avatar
    Sending error reports to google when you link your gmail account I remember i unchecked it around there.
    But in settings I'll play with it tomorrow and see if i can find it. I haven't been in android game in 5 months or so since work gave me. Unlimited data and iPhone 5s free.
    But I'll figure it out and let yall know when I find it. But looking at his shot it's not showing a wake lock only wifi so something there isn't correct.
    What ghz connection is it 2.4? I would do a factory reset and look for that box and uncheck it. Maybe something is corrupt In the start up processes?
    I do this with every phone I get new..
    I buy it charge it fully
    Set it up. Charge it fully
    Leave on night stand with everything on for 12+ hours go back to it with 2 or 3 different battery monitors like gsm and see if there is something keeping the phone awake or corrupt apps from Samsung
    Then 12 hours with it off wifi and repeat with screenshots and check the pattern and see if something is wrong if not your golden. If you find a bad factory device you now have 13 days to exchange it and 2 years to play with it. Be patient
    04-11-2015 12:22 AM
  20. kinosaji's Avatar
    Attached Thumbnails Verizon GS6 has no cell stand by battery issues-screenshot_2015-04-10-22-42-25.jpg
    04-11-2015 12:45 AM
  21. codysanbor's Avatar
    Not bad.. just standby no use at all
    Messenger was running in background also
    Searching for that check box now
    04-11-2015 05:40 AM
  22. STEVESKI07's Avatar
    Well it looks like my battery drain issue I was having or at least I thought I was having yesterday didn't seem to affect me over night. Maybe it's an issue when I'm not at home? I'll do some more testing today.
    Attached Thumbnails Verizon GS6 has no cell stand by battery issues-1428750177643.jpg
    04-11-2015 06:03 AM
  23. codysanbor's Avatar
    Can't find it... only seen it setting up as new phone
    04-11-2015 06:07 AM
  24. edgefever's Avatar
    04-11-2015 08:34 AM
  25. DaMaRa1109's Avatar
    I haven't been on android for about a year but this seems very high, no?
    S6 Edge
    04-11-2015 08:44 AM
93 1234
  1. Galaxy S6: External Speaker Quality
    By codysanbor in forum Samsung Galaxy S6
    Last Post: 06-13-2015, 12:08 PM
  2. Is the quick charging limited by the USB cable?
    By AlphaVictor87 in forum Samsung Galaxy S6
    Last Post: 04-10-2015, 05:29 PM
