For the life of me, I can't figure out where I set this. If you can let us know it would be really appreciated.
Sending error reports to google when you link your gmail account I remember i unchecked it around there.
But in settings I'll play with it tomorrow and see if i can find it. I haven't been in android game in 5 months or so since work gave me. Unlimited data and iPhone 5s free.
But I'll figure it out and let yall know when I find it. But looking at his shot it's not showing a wake lock only wifi so something there isn't correct.
What ghz connection is it 2.4? I would do a factory reset and look for that box and uncheck it. Maybe something is corrupt In the start up processes?
I do this with every phone I get new..
I buy it charge it fully
Set it up. Charge it fully
Leave on night stand with everything on for 12+ hours go back to it with 2 or 3 different battery monitors like gsm and see if there is something keeping the phone awake or corrupt apps from Samsung
Then 12 hours with it off wifi and repeat with screenshots and check the pattern and see if something is wrong if not your golden. If you find a bad factory device you now have 13 days to exchange it and 2 years to play with it. Be patient
