Verizon GS6 has no cell stand by battery issues
elter
Active member
Apr 14, 2015
27
Same problem here. VZW S6 Edge.. I've unchecked 'Always allow wi-fi scanning' and set location services to only use GPS to see if it makes any difference. I read on reddit that some people had better luck with Advanced calling _enabled_ on VZW. It may make some sense if the problem is indeed with cell _standby_ functionality which is activated only when wifi is on if I understand this properly.
If so, enabling Advanced calling may force your phone to always keep LTE connection active and not in standby mode. I'll try it if WiFi tweak I made doesn't help.
Also, Can somebody post some additional info about Cell standby? I'm looking for 'Time on' and 'Total connection time' metrics reported by Samsung Battery app. Concluding the things I read here and on reddit I'd expect to see battery drain issues when 'Time on' value is way higher than 'Total connection time'
Seth Lake
Yesterday 30% of my battery drain was due to cell stand by and I've also noticed that my cell reception has degraded ever since I've switched. My house always gets 3G my s6 doesn't recognize it and now my phone calls having been dropping a lot. Anyone else seen a drop in signal as well?
mactruck
62
For the people who were asking about Google settings and sending error reports.
Go to Google Settings App. 3 dots top right and click usage and diagnostics. Turn off.
elter
Active member
Apr 14, 2015
27
Ok, I think I have some additional data points here.. It looks like 'cell standby' category is just misleading. We assumed that it had something to do with actual cellular radio, which was only partially true. In fact, standard Battery reporting app includes WiFi usage to this category. This explains why people see huge battery drain only when wifi is connected. That's what I did to come to this conclusion:
1. Factory reset
2. After confirming that the problem was still there, I installed Spotify GSam battery monitor and started downloading my playlists over wifi.
After ~ 20 mins of downloading, I found that the only increased value in Battery app was in fact 'Cell standby' but GSam reported 99% of battery for that time period was consumed by WiFi. See screenshots attached. So, it looks like a lollipop bug which affected many manufacturers and nexus devices one way or another. Check reports for LG G3 Lollipop updates, galaxy s5 etc. Google 'lollipop wifi battery drain'. I'm not even sure who to blame at this point. VZW for approving such lollipop updates? Samsung for pushing new device to US market with raw OS. Google for buggy release?
At this point I fell like disabling WiFi scanning and letting device sleep with no wifi unless it's plugged in would be somewhat acceptable workaround until this issue is resolved.
Thoughts?
elter
Active member
Apr 14, 2015
27
Somehow, Advanced Calling enabling on my line,in the phone settings and restarting it fixed the problem. I'll wait for a day or so to confirm this but my phone has been 'cell standby' problem free for more than an hour.
mactruck
62
First one is before I went to bed. It sat on my night stand and I woke up to this.
Not sure what is draining it over night
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
T-Mobile version here. Tested something last night... I kept wifi and wifi calling on but changed to my 2.4 GHz network versus my 5 GHz network at home.. Drain was extremely light (1.1% an hour) .
