1. David Ciszewski's Avatar
    Within 25 minutes I lose 10% by a real quick check clash of clans a short phonecall being on andorid central. I turned off the 2 recommend WiFi settings and still draining.
    04-11-2015 09:48 AM
  2. clevin's Avatar
    number seems reasonable, you will have to use it for longer time and post some screenshot.
    Almeuit likes this.
    04-11-2015 10:03 AM
  3. racedog's Avatar
    Wow, I've only had the phone since yesterday afternoon and been doing a lot of app restores (including downloading), trying various things in setup and doing some surfing and I'm not experiencing anything like that kind of drain. I don't have any suggestions for you but it doesn't sound like a normal amount of battery drain. Maybe others in here will have some suggestions for you but if my phone were doing that it would not be acceptable. I would probably try a reset and if that didn't work I would likely return the phone.
    Almeuit likes this.
    04-11-2015 10:06 AM
  4. Inders99's Avatar
    Maybe the mods can combine some of these threads, they're starting to breed like rabbits
    20blks likes this.
    04-11-2015 10:21 AM
  5. David Ciszewski's Avatar
    First android of mine switched from blackberry mostly and the first iphone. The Z30 battery life as amazing with out a battery saving mode. Not use to a ton of features. More of a business man I guess. Slowly getting rid of my ipad for this phone and the 2 in 1 Asus transformer flipbook so I carry less devices for college. Now at 79%
    04-11-2015 10:29 AM
  6. David Ciszewski's Avatar
    This is what's going on in the battery monitor setting section of settings
    Attached Thumbnails massive battery drain Verizon Galaxy S6 Edge-209.jpg   massive battery drain Verizon Galaxy S6 Edge-208.jpg
    04-11-2015 10:35 AM
  7. bbogert79's Avatar
    I have the regular screen S6. I am not impressed with battery life.. I went to bed last night and took my phone off charger at 100%.. Slept 7 hours woke up still at 100%.. I was impressed with that... Use my phone for 10 mins to check news and weather and went down to 90% in just 10 min of use!!
    04-11-2015 12:49 PM
  8. mountainman15's Avatar
    That seems high. My battery seems to drop about 1% every 5 minutes with similar use (checking news, Twitter, weather, etc).
    04-11-2015 12:56 PM
  9. clevin's Avatar
    You cannot assess battery based on 10 min use. Use it until battery approaches 10% and then post some screen shot.
    bbogert79 likes this.
    04-11-2015 01:21 PM
  10. clevin's Avatar
    Tap the item "screen", how many hrs does it say for screen on time?
    If would be normal if the screen was on the entire time.
    04-11-2015 01:22 PM
  11. tolga ciftci's Avatar
    Do you still have the same problem! I am facing the same thing and not sure if there is a resolution out there! Would appreciate the input.
    04-15-2015 03:16 PM
  12. David Ciszewski's Avatar
    Still pretty bad but not as bad since Samsung push update
    04-26-2015 01:49 AM
  13. Inders99's Avatar
    You might want to read this, the 100-90 is explained:
    http://phandroid.com/2010/12/25/your...h-a-bad-thing/
    Here's the thread:
    http://forums.androidcentral.com/sam...ml#post4386306
    04-26-2015 06:46 AM
  14. Bwahahahaha's Avatar
    Hey man, what theme is that??
    04-26-2015 07:05 AM
  15. David Ciszewski's Avatar
    Space
    04-26-2015 11:12 PM
  16. Zoostation's Avatar
    Here's the thread:
    Having read the article, it still pisses me off that the screen doesn't show an accurate reading at all times.
    04-26-2015 11:40 PM
  1. HELP! How to mass link contacts on galaxy s4 running Lollipop 5.0.1?
    By Markus_of_Gaia in forum Samsung Galaxy S4
    Last Post: 05-12-2015, 12:22 PM
  2. Turn off LTE? Battery drain.
    By Tami Harris1 in forum Samsung Galaxy S6
    Last Post: 04-17-2015, 10:03 PM
  3. Replies: 1
    Last Post: 04-11-2015, 09:37 AM
  4. Replies: 1
    Last Post: 04-11-2015, 09:28 AM
  5. HTC one m8 battery issues
    By ankit_xs in forum Ask a Question
    Last Post: 04-11-2015, 09:18 AM
