12-22-2017 07:20 AM
72 123
tools
  1. DanPLC's Avatar
    Last night I used the official Samsung wireless charger to charge my phone overnight. The battery graph shows it reached 100% at 2am, but then dropped back down to 92% when I picked it up in the morning.
    The highest battery usage app was "Connection Optimizer" with 2% usage which doesn't seem like a lot. I've disabled it under the "Mobile Networks" setting so we'll see if that helps. But somehow I doubt that was causing the drain.
    Anyone else see this type of thing while charging their phone overnight on a wireless charger?
    04-12-2015 07:17 AM
  2. jcp007's Avatar
    On AT&T, I am using my OEM charger and have not had this issue.
    04-12-2015 08:11 AM
  3. Frenzytom's Avatar
    I've has that issue as well. Most mornings it tops off at 98% and stays there. The fast charger always gets it to 100% and then stops charging.
    04-12-2015 10:45 AM
  4. cohoman's Avatar
    I'm using the Duracell wireless charger with my S6 in a Spigen thin case and it charges up to 100% (showing the green notification light).
    20blks likes this.
    04-12-2015 10:50 AM
  5. smooth4lyfe's Avatar
    Same here mine charges to 100% as well
    I would deplete the battery and recharge it
    04-12-2015 10:51 AM
  6. cwise222's Avatar
    Perhaps the Samsung wireless charger shuts off when the phone hits 100% and does not reactivate until the phone is placed on it again? I swear I saw a post somewhere mentioning that as an 'energy saver' type of thing. I only use my wireless charger for top off when I'm at the office so I've never had it on long enough to hit 100%.
    Doug Butler likes this.
    04-12-2015 11:22 AM
  7. jimbl's Avatar
    I have a strange thing going on also. I've only had the phone 3 nights. First 2 nights it charged to 100% on the Samsung Wireless Charger. Last night, I woke up to the charging pad blinking, the phone not charging, and the phone at 93%. It hadn't charged for 4+ hours when I checked the batter stats. We'll see what happens tonight.
    04-13-2015 08:44 AM
  8. jcp007's Avatar
    100% this morning.
    Posted via My Samsung Galaxy S6 Handheld Device
    04-13-2015 09:01 AM
  9. stirling's Avatar
    On the Samsung wireless charger, mine appears to shut off once the phone gets to 100%, and then I have whatever I have when I get up. Like others it seems like the wireless pad doesn't come back on once it shuts down.
    Doug Butler and jrb3rd like this.
    04-13-2015 09:13 AM
  10. jschu22's Avatar
    Ive had the flashing light as well. I also noticed last night that the charger seemed to be a bit more particular with the position of the phone on it. It might have been me and being half asleep but I really think that it didn't have to be so precise on previous charges.
    04-13-2015 10:52 AM
  11. jcp007's Avatar
    The green LED lights up on the OEM charging pad when it's fully charged.
    04-13-2015 10:56 AM
  12. mhettrich's Avatar
    Using a Tylt wireless charger my phone reaches 100% without any issues.
    04-13-2015 10:58 AM
  13. DWS44's Avatar
    So far, I've done two nights on the Samsung Wireless Charger. First morning, I had the same exact result as the OP...woke up to 93%. I assumed it was as others mentioned, that it had charged to 100% and shut off. This morning, though, I woke up to a full 100%...same conditions as the previous night.
    04-13-2015 11:23 AM
  14. sjaduae's Avatar
    I've had similar issues for the last 4 nights with Samsung charger
    At 1st I thought it was reaching 100% and not turning back on, but it seems to vary especially if you get a message overnight.
    Several times (as I tested it also during the weekend daytime) it would reach 100% and turn green then a few hours later turn to flashing purple and a few times it has stayed green for hours
    Like a dummy I threw the manual away and there is not a PDF on Sammy site to explain the flashing alert on the charger
    Something seems to interrupt the staying on 100% or from re-intialising
    04-13-2015 02:14 PM
  15. unashamedgeek's Avatar
    Just started using the Samsung wireless charger and am having the same issue. Looks like I'll be buying a new wireless charger for my bedside and I'll turn this one into my office charger.
    04-21-2015 01:03 PM
  16. claykin's Avatar
    New OEM Samsung wireless charging pad (round disc) will charge to 100% then LED turns green for a short time before the charger powers off. Charger will only power on again if you lift phone off then return to the charger.
    Unfortunately, Samsung did not include a "top up" function for their wireless charger. This charger is not the best option for overnight charging as you'll surely wake up to less than 100% charge.
    04-26-2015 03:45 PM
  17. Jaycemiskel's Avatar
    This has been my experience too. Glad it was free!
    04-26-2015 05:24 PM
  18. jcp007's Avatar
    Just a thought...why not turn off the phone at night?
    04-26-2015 06:22 PM
  19. Jaycemiskel's Avatar
    I prefer to keep my phone on all night. Never know when there might be an emergency.
    claykin likes this.
    04-26-2015 08:18 PM
  20. jcp007's Avatar
    We have a land line and my wife uses hers as an alarm clock. If you have a land line, missed calls would be less of an issue.
    04-27-2015 05:49 AM
  21. Raymond Elliott's Avatar
    I tried the new Samsung round puk charger and found it does turn off after 100% charge. I also have the older square Samsung "mini" charger. It stays on and keeps the phone charged to 100%. I also stream radio all night and still wake up to a 100% charge.
    This is the one:
    Amazon.com: Samsung Mini Wireless Charging Pad - Retail Packaging - Black: Cell Phones & Accessories
    04-27-2015 08:19 AM
  22. ziggster's Avatar
    I actually watched my oem charger go into the blue blinking mode one night and stop charging. It happened when a notification made the screen turn on momentarily.
    I have since purchased this http://www.amazon.com/Wireless-Charg...cUvbUpU4389481 and now wake up every morning to a fully charged phone. Placement is much easier, also.
    04-27-2015 08:40 AM
  23. jschu22's Avatar
    Are you posting this from 1993?
    jimbl, DWS44 and clintw22 like this.
    04-27-2015 11:42 AM
  24. jimbl's Avatar
    What's this "land line" you speak of? Is it at all related to this thing called "fax"?
    04-27-2015 11:51 AM
  25. Jaycemiskel's Avatar
    Yeah, I don't have a landline. And both my wife and I have different schedules so we both use our own as alarms.
    04-27-2015 12:46 PM
72 123
  1. Keeping The S6 Edge Connected to the Fast Charger?
    By DrRob72 in forum Samsung Galaxy S6 edge
    Last Post: 01-08-2016, 07:01 PM
  2. Transfer iPad iBooks library to Galaxy S6
    Last Post: 05-01-2015, 11:21 AM
  3. Transferingnfrom internal storage to sd card
    Last Post: 04-12-2015, 07:47 AM
  4. My phone is not starting up.
    Last Post: 04-12-2015, 07:18 AM
  5. Bluetooth name on LG G3 phone
    Last Post: 04-12-2015, 06:13 AM
